atomic_read & set will act as memory barrier?
softarts
I remember someone said on WIN32, read/set volatile variable willimplicitlycarry a memory fence
but how is it on Linux?
no memory fence when read/set volatile variable?
RafSchietekat
Valued Contributor III
Some compilers do that, but it is not and never will be standard behaviour, so don't write nonportable code that will fail with your most likely weapon of choice on Linux (g++). It is a compiler issue rather than an O.S. one, though: if I'm not mistaken, Intel's icc does this on Linux as well as on Windows (configurable?).
Dmitry_Vyukov
Quoting softarts
Yes, gcc does not emit any memory fences for volatile reads/writes.
