auto_partitioner performance
eugene-klyuchnikov
auto_partitioner should be a good choice for the most common problems. But...
I've tried the following code:
[cpp]class RenderByLines {
	LPDWORD* const my_lines;
public:
	void Perform(const int from, const int to) const {
		LPDWORD* lines = my_lines;
		for (int yy = from; yy != to; yy++) {
			int y = 127 - (yy / 2);
			if ((yy & 0x1) == 1) {
				y = 255 - y;
			LPDWORD line = lines;
			for (int x = 0; x < 256; x++) {
				int q = 1;
				for (int z = 0; z < 256; z++) {
					q = (q * x + z) * y;
				line = x + (256 * y) + (65536 * (q & 0xFF));
	void operator()(const blocked_range& r) const {
		Perform(r.begin(), r.end());
	RenderByLines(LPDWORD* lines) :
		my_lines(lines)
void testPF() {
	tick_count t0 = tick_count::now();
	parallel_for(blocked_range(0, 256, 1), RenderByLines(microLines));
	tick_count t1 = tick_count::now();
	fprintf(debugFile, "test parallel_for: %d mksn", (int)((t1-t0).seconds() * 1000000));
void testPFA() {
	parallel_for(blocked_range(0, 256), RenderByLines(microLines), auto_partitioner());
	fprintf(debugFile, "test parallel_for_auto: %d mksn", (int)((t1-t0).seconds() * 1000000));
void testS() {
	RenderByLines(microLines).Perform(0, 256);
	fprintf(debugFile, "test sequential: %d mksn", (int)((t1-t0).seconds() * 1000000));
void PerformParallelRaytrace() {
	for (int i = 0; i < 8; i++) {testPF();}
	for (int i = 0; i < 8; i++) {testPFA();}
	for (int i = 0; i < 8; i++) {testS();}
[/cpp]
And got results:
[plain]test parallel_for: 102283 mks
test parallel_for: 74223 mks
test parallel_for: 74463 mks
test parallel_for: 78521 mks
test parallel_for: 80608 mks
test parallel_for: 76435 mks
test parallel_for: 78746 mks
test parallel_for: 76028 mks
test parallel_for_auto: 77084 mks
test parallel_for_auto: 79055 mks
test parallel_for_auto: 69775 mks
test parallel_for_auto: 74822 mks
test parallel_for_auto: 80514 mks
test parallel_for_auto: 76490 mks
test parallel_for_auto: 92116 mks
test parallel_for_auto: 92822 mks
test sequential: 122995 mks
test sequential: 128488 mks
test sequential: 120866 mks
test sequential: 121859 mks
test sequential: 120693 mks
test sequential: 120593 mks
test sequential: 120668 mks
test sequential: 120733 mks
test parallel_for: 71991 mks
test parallel_for: 73140 mks
test parallel_for: 73169 mks
test parallel_for: 71933 mks
test parallel_for: 73696 mks
test parallel_for: 73777 mks
test parallel_for: 73173 mks
test parallel_for: 77050 mks
test parallel_for_auto: 77619 mks
test parallel_for_auto: 74510 mks
test parallel_for_auto: 76760 mks
test parallel_for_auto: 73786 mks
test parallel_for_auto: 74553 mks
test parallel_for_auto: 73108 mks
test parallel_for_auto: 73642 mks
test parallel_for_auto: 73634 mks
test sequential: 120947 mks
test sequential: 120867 mks
test sequential: 122299 mks
test sequential: 120984 mks
test sequential: 121005 mks
test sequential: 120843 mks
test sequential: 120354 mks
test sequential: 120945 mks
[/plain]
Seems to be very strange. When there were no internal cycle (calculating q) - auto_partitioner worked good - is was about 15% faster. But on long lasting computations - auto_partitioner consumes about 2 additional milliseconds!
I can't understand this result.
Anton_Pegushin
New Contributor II
Hi, I'm thinking it's easy to check for the imbalance Raf is talking about. You have a maximum of 256 tasks, so add a static vector of size 256to RenderByLines class and inside operator() just store the "to"s as a "from" element (iteration_size[r.begin()] = r.end();). For auto_partitioner this would tell you how large the grain size is really and if there is an imbalance with minimal distortion. If the work turns out to be balanced, but the grain size will be greater than 1, I'd suggest profiling and looking at cache behavior.
RafSchietekat
Valued Contributor III
Wild (meta) guess: auto_partitioner has to make a guess about a good division of work between the cores, and if it guesses slightly wrongly (which is bound to happen), some cores finish earlier than others, but cannot steal work from the threads that are still busy,which is not a problem with simple_partitioner and grainsize 1, as long as the task overhead is limited relativeto the amount of work that a task does. You'll probably seeincreasing runtimes (if you want to be distinguishing such small differences) with manually increasing grainsizes, probablywith an optimum in-between. If your program is doing other things than just this and waiting until the finish, auto_partitioner should still provide best results.To verify,run the outer loop of8iterations in parallel instead(use simple_partitioner and 1), to give TBB the chance to amortise the final wait to zero, and then please report back (I'm curious).
Anton_Pegushin
New Contributor II
eugene-klyuchnikov
Great idea. Don't know what was this morging, but now auto_partitioner works just as expected (may be it has a 7-th sence ;-)
Here is the new code sample:
[cpp]void testPFA() {
	for (int i = 0; i < 256; i++) {intervals = -1;}
	for (int i = 0; i < 256; i++) {if (intervals >= 0) {fprintf(debugFile, "%d ", intervals - i);}}
	fprintf(debugFile, "nn");
[/cpp]
... and new result:
[plain]test parallel_for: 60229 mks
1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1
test parallel_for_auto: 60136 mks
64 64 32 32 32 32
test sequential: 118471 mks
[/plain]
So, thanks.
RafSchietekat
The work could be nominally balanced (in the range domain), but actually unbalanced (some elements requiring more work than others and/or interference from other threads or processes). For the diagnostic output to really make sense (I have not checked the implementation of auto_partitioner), we'd also have to know the number of cores (the numbers in #3 seem unproblematic for 2 cores), and perhaps timing results for each body invocation (2% may be consistent with accidental differences).
Random thought (just to free my mind): how about a hint to auto_partitioner about some range statistics estimates, like maximum ratio in iteration execution times (bigger ratio=>smaller bites), perhaps correlation between neighbours, cost of splitting, ...
