Hello everyone!
I have changed the serial program with Intel TBB,now it is a parallel program. I run the program with vs2010,but it doesn't work with x64.Is TBB can't work with x64?
Thank you!
did you compile 64-bit version on TBB?
--Vladimir
--Vladimir
Yes ,I compile 64-bit version on TBB ,but it can't work.
Do "can't work" mean can't load, can't start, crash or wrong results?
--Vladimir
--Vladimir
When build solution,appear the error like this:
1>MessageBuildingWithCompiler:
1> Building with Intel(R) C++ Compiler XE 14.0
1>ClCompile:
1> ***** ClCompile (x64 - Intel C++)
1> box.cpp
1>D:\mypictbb\mypic\mypic\StdAfx.h(13): error : cannot open source file "tbb/parallel_for.h"
1> #include "tbb/parallel_for.h"
--Vladimir
When i build solution,appear error like this:
1>ClCompile:
1> box.cpp
Did you changed "Use Intel TBB" to "yes" for x64 platform? Its value it configuration specific.
Yes,when i change win32 to x64,I forget change "Use Intel TBB" to "yes" for x64 platform,thank you,dear friend!
