catastrophic error: cannot open source file "tbb/parallel_for.h"
Nadisanka_R_
I am relatively new to ICC, TBB and just started learning. Currently I am trying to compile a test code given for tbb in GettingStarted folder in side /opt/int/composer_xe_2015.1.133/tbb/examples. but unfortunately the compilation fails with the following error.
I set all the paths by executing the compilervars.sh shell script. With export command I can see paths have been set properly (CPATH. LD_LIBRARY_PATH). Please kindly provide a suggestion to solve this issue. This is taking soo much of time.
BTW my system is Ubuntu 14.04 LTS
Thank you!
Zank
Vladimir_P_1234567890
did you source iccvars.sh or tbbvars.sh?
--Vladimir
