2456 Discussions
catastrophic error: could not open source file "nr.h"
dineshparallel
when i try to execute a matrix multiplication program in visual studio 2008 by using intel parallel studio(trial) i faced the following error
Compiling with Intel C++ Compiler 11.1.071 [IA-32]... (Intel C++ Environment)
matrixmul.cpp
matrixmul.cpp(4): catastrophic error: could not open source file "nr.h"
#include "nr.h";
Please suggest the solution to this error
Vladimir_P_1234567890
hi,I can't recall matrixmul.cpp file in TBB. could you point where it is? thanks,
--Vladimir
