concurrent_monitor bug
Blas_Rodriguez_Somoz
There is a bug in concurrent_monitor.cpp/h when compiled withTBB_USE_ASSERT=1 TBB_USE_DEBUG=0
There is an assertion in the concurrent_monitor destructor which verify the waitset is empty, but in four places inside this files the waitset is cleared only where TBB_USE_DEBUG is true (look for "temp.clear()").
When compiled with previously mentioned settings, the waitset is not cleared and the assertion in the constructor fails.
I patched the #if's, the minimal change to be able to build, and I'llsubmit the patch though the submision form ASAP.
The waitset is in all the 4 places a temporary object and the clear() is the last instruction before the end of the definition scope, so the #if seems OK, since the clear function only resets value of some internal variables.
void clear() {head.next = &head; head.prev = &head;__TBB_store_relaxed(count, 0);}
RafSchietekat
Valued Contributor III
I guess you meant ~circular_doubly_linked_list_with_sentinel(), instead of ~concurrent_monitor()? That I would confirm, although I only see 3 such uses in concurrent_monitor.{h,cpp}, instead of 4.
Excuse me, you are right in both comments.
I'm talking about thecircular_doubly_linked_list_with_sentinel destructor not the concurrent_monitor one.
There are only 3 "temp.clear()", the fourth correction is in the "#if !TBB_USE_DEBUG" around the private keyword incircular_doubly_linked_list_with_sentinel which must be changed to "#if !TBB_USE_DEBUG && !TBB_USE_ASSERT".
RafSchietekat
How about this?
[cpp]#if !TBB_USE_ASSERT
private:
#endif
private:
    __TBB_atomic size_t count;
    node_t head;
[/cpp]
Yes, it is OK, the TBB_USE_DEBUG isn't needed here.
Wooyoung_K_Intel
Could you give us more detail?
I don't seem to reproduce the issue.
temp.clear() is wrappend around by '#if TBB_USE_ASSERT', it is called when TBB_USE_ASSERT==1; and __TBB_ASSERT is defined when TBB_USE_ASSERT==1.
And, could you check if you have the latest TBB release?
thanks
I suppose it is because someone patch the bug after I report it.
[bash]    }
#if TBB_USE_DEBUG
    temp.clear();
#endif
[/bash]
This is the code in version 20111130, which was the most recent one when I report the issue.
As you can see it uses TBB_USE_DEBUG instead of TBB_USE_ASSERT
Wooyoung_K_Intel
That seems to be the case. Thanks.!!
The fix will be in the next TBB release.
