concurrent_unordered_map requires index to be default constructible
klaim
I'm using ITBB 4.1 and I have this problem that concurrent_unordered_map can't compile without the index type being default constructible.
However this don't follow C++ containers requirements (in C++11 at least).
Most of the time this wouldn't be a big problem, but it prenvents me to do this for example:
[cpp]
tbb::concurrent_unordered_map< std::type_index, MyFunctor > m_translation_table;
[/cpp]
See http://en.cppreference.com/w/cpp/types/type_index
I think I'll use a type_info pointer instead but this is not supposed to be portable AFAIK.
So, are there plans to fix this? Or does the concurrency feature prevent accepting non-default-constructible indice?
Anton_P_Intel
klaim, Thanks for reporting it. Interesting use case. TBB team will consider if it possible/feasible to implement.
klaim
Anton, did you have time to check if this can be fixed?
Christophe_H_Intel
Sorry for the delay; I have a patch file that you can apply to include/tbb/internal/_concurrent_unordered_impl.h to remove the requirement that a default constructor be available.  (The fix is for the TBB U2 version.)
Thanks for the report.
Chris
klaim
Thanks, I will be able to try it next week.
What is the U2 version of TBB?
Christophe_H_Intel
It is the newest update for TBB 4.1.  It's available now on threadingbuildingblocks.org.
Thanks again, and I appreciate the container is useful to you.
Chris
klaim
I just tried to use this patch, had to do it by hand but it's not very complicated.
It seem to compile but I can't test runtime yet, I'll report if there are problems or not.
Question: will this change be implemented in the next TBB versions?
Vladimir_P_1234567890
It have been released in current update 3
--Vladimir
klaim
Nice! I'm upgrading my TBB version right now. Thanks guys!
Unfortunately these containers also have a big problem which is they don't allow move-only values like std::unique_ptr. I don't know yet how to get around this problem in my case, maybe just using std::shared_ptr instead but it looks like a waste of speed.
