Guys, do I understand it correctly that if I have an object of class concurrent_vector filled with some values and if I put this object to parallel_for while specifying blocked_range on this vector then, the task scheduler will automatically spread the load on all available cores?
Thank you.
Thank you.
A normal vector will do at least as well, but that's the general idea.
