Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
core dump on Assertion failure
Jump to solution
I saw a core dump due to such assertion failure. I start having this failure after integrate some third party libraries into my system. I suspect that third-party library is using some native thread. But still it does not make sense to crash tbb.
I'm using Tbb on fedora20 x86-64.
Assertion block->checkFreePrecond(object) failed on line 2396 of file ../../src/tbbmalloc/frontend.cpp
Detailed description: Possible double free or heap corruption.
My question is: what does this failure mean?
Accepted Solutions
@Vladimir, @Alexandr, Thanks for your suggestions.
I'm able to track down the problem. It's not related to tbb, though the runtime reported error on tbb assertion. Other libraries cause this problem.
Highlighted
Hello Lucan,
Do you have a backtrace to understand where this second scalable_free() is called from?
--Vladimir
Highlighted
This might be related to this forum thread https://software.intel.com/en-us/forums/topic/520693.
--Vladimir
Highlighted
Hi Vladimir,
Thanks for the suggestion.
Here's my super simple example which's having this assertion failure.
#include <iostream>
#include "tbb/task_scheduler_init.h"
int main() {
  tbb::task_scheduler_init t;
  	std::cout << "Hello World!!!" << std::endl;
  	return 0;
build script:
g++ src/*.cc -g -pthread -L"tbb43_20140724oss/lib/intel64/gcc4.4/" -L"aap/lib/" -ltbb_debug -ltbbmalloc_debug -ltbbmalloc_proxy_debug -laapapi1 -laapapi2 -I"tbb43_20140724oss/include/" -o execute
Note:
aap is my third-party library, I linked with aapapi1 and aapapi2. In the example, I only initialize tbb and did not even use aap.
backtrace:(please see attached file, if I paste the bt here, my submission will trigger the system spam filter. I uploaded a screenshot)
--Vladimir
Highlighted
Lucan, Could you try build your small reproducer without -ltbbmalloc_debug and -ltbbmalloc_proxy_debug? And than run resulted executable (do not dependent on libtbbmalloc_debug) under tool like Valgrind to check double-free presence?
