2457 Discussions
cpu performance w/a simple gather utility
Petros_Mamales
I have an i7 965 cpu running on win7 and using tbb 3.0.
The attached program, is designed to gather into a (clumn format) matrix elements that live in different buffers
(in this case a bigger matrix).
I am trying to see how many processing units (out of 8?) are engaged in the calculation. From the task mgr
I see at most 4.
[cpp]//stl
#include
using std::vector;
//tbb
//tbb
#include "tbb\parallel_for.h"
#include "tbb\parallel_reduce.h"
#include "tbb\blocked_range.h"
#include "tbb\blocked_range2d.h"
// function to gather data into a single matrix as columns
template< typename _M, typename _T>
void gather_data_into_matrix_columns( _M & m, vector<_T*> const & dataStart, vector const & dataStride ){
	struct column_gatherer{
		_M & m_;
		vector<_T*> const & dataStart_;
		vector const & dataStride_;
		column_gatherer( _M & m, vector<_T*> const & dataStart, vector const & dataStride )
			:m_(m), dataStart_(dataStart), dataStride_(dataStride)
		void operator()( const tbb::blocked_range2d< size_t > & r ) const {
			size_t rowStart = r.rows().begin();
			size_t rowEnd = r.rows().end();
			size_t colStart = r.cols().begin();
			size_t colEnd = r.cols().end();
			for ( size_t colIdx = colStart; colIdx != colEnd; ++colIdx ){
				size_t stride = dataStride_[colIdx];
				_T const * ptr = dataStart_[colIdx] + rowStart * stride;
				for ( size_t rowIdx = rowStart; rowIdx != rowEnd; ++rowIdx ){
					m_( rowIdx, colIdx ) = *ptr;
					ptr += stride;
	static const size_t GRAIN_SIZE_ROW = 10;
	static const size_t GRAIN_SIZE_COLUMN = 10;
	column_gatherer cg( m, dataStart, dataStride );
	tbb::parallel_for(
			tbb::blocked_range2d(
				0, m.size1(), GRAIN_SIZE_ROW,
				0, m.size2(), GRAIN_SIZE_COLUMN
			cg,
			tbb::auto_partitioner() );
#include
using std::cout;
using std::endl;
#include
using boost::numeric::ublas::matrix;
bool test_GatherScatter(){
	const size_t nRows = 80;
	const size_t nCols = 20;
	matrix< double, boost::numeric::ublas::column_major> m(nRows,nCols);
	const size_t nRowsBig = 800;
	const size_t nColsBig = 100;
	matrix< double, boost::numeric::ublas::column_major> mBig(nRowsBig,nColsBig);
	for ( size_t i = 0; i != nRowsBig; ++i ){
		for ( size_t j = 0; j != nColsBig; ++j ){
			mBig(i,j) = double(rand())/double(RAND_MAX) - 0.5L;
	vector< double *> colStart( nCols );
	vector< size_t > strides( nCols );
	for ( size_t i = 0; i != nCols; ++i ) {
		colStart = &(mBig(0,3*i));
		strides = 5;
	gather_data_into_matrix_columns( m, colStart, strides );
	for( size_t i = 0; i != nRows; ++i ){
		for( size_t j = 0; j != nCols; ++j ){
			if ( m(i,j) != mBig( 5*i, 3*j) ){
				cout << "(i, j) = (" << i << ", " << j << ")" << endl;
				return false;
	return true;
int main(){
	bool b;
	for ( size_t i = 0; i != 1000; ++i )
	b = test_GatherScatter();
[/cpp]
Is this a reliable test? Is there a better one than eyeballing it ;)) ?
The code is a concatenation of various files. Conceptually gives the right result. Please, let me know if there is something more you might need.
Thank you very much for your help,
Petros
ps: the motivation for this is to bring into one place (typically a matrix) data that will constitute the rhs of lapack linear equation solver.
RafSchietekat
Black Belt
