crash with -flto and Ubuntu 16.04.2 and g++-6
Peter_F_1
#0  0x00007ffff6d5a799 in tbb::internal::intrusive_list_base<tbb::internal::intrusive_list<tbb::internal::generic_scheduler>, tbb::internal::generic_scheduler>::push_front(tbb::internal::generic_scheduler&) ()
    at ../../src/tbb/intrusive_list.h:175
#1  tbb::internal::generic_scheduler::create_master(tbb::internal::arena*) (a=0x0) at ../../src/tbb/scheduler.cpp:1181
#2  0x00007ffff6d4611c in tbb::internal::governor::init_scheduler_weak () at ../../src/tbb/governor.cpp:178
#3  tbb::internal::governor::local_scheduler_weak () at ../../src/tbb/governor.h:140
#4  tbb::internal::allocate_root_with_context_proxy::allocate (this=0x7fffffff8d60, size=88)
    at ../../src/tbb/task.cpp:67
anybody any clue?
It works fine in debug mode (using tbb_debug.so).
I only did minor changes to tbb2017_20161128oss/build/linux.gcc.inc:
35,36c35,36
< CPLUS = g++
< CONLY = gcc
> CPLUS = g++-6
> CONLY = gcc-6
71c71,73
<         CPLUS_FLAGS = $(ITT_NOTIFY) -g -O2 -DUSE_PTHREAD
>         CPLUS_FLAGS = $(ITT_NOTIFY) -g -O3 -DUSE_PTHREAD -flto=8 -funroll-loops -ffast-math -march=native
>     LINK_FLAGS += $(CPLUS_FLAGS)
>     LIB_LINK_FLAGS += $(CPLUS_FLAGS)
Peter_F_1
this also seems to be true, without -flto and even when replacing -O3 with -O2 or even with a nearly original linux.gcc.inc (only compilers changed to version 6). Only when using libtbb_debug.so it is not crashing. BTW the code is clean regarding valgrind.
Alexey-Kukanov
If your version of TBB precedes 4.4.6, please upgrade. TBB 4.4.6 is the minimal version that works with GCC 6.
Peter_F_1
Alexey-Kukanov
Correct. Since TBB 4.4.6, the -flifetime-dse=1 option is added to the TBB makefiles.
