#0 0x00007ffff6d5a799 in tbb::internal::intrusive_list_base<tbb::internal::intrusive_list<tbb::internal::generic_scheduler>, tbb::internal::generic_scheduler>::push_front(tbb::internal::generic_scheduler&) ()
at ../../src/tbb/intrusive_list.h:175
#1 tbb::internal::generic_scheduler::create_master(tbb::internal::arena*) (a=0x0) at ../../src/tbb/scheduler.cpp:1181
#2 0x00007ffff6d4611c in tbb::internal::governor::init_scheduler_weak () at ../../src/tbb/governor.cpp:178
#3 tbb::internal::governor::local_scheduler_weak () at ../../src/tbb/governor.h:140
#4 tbb::internal::allocate_root_with_context_proxy::allocate (this=0x7fffffff8d60, size=88)
at ../../src/tbb/task.cpp:67
anybody any clue?
It works fine in debug mode (using tbb_debug.so).
I only did minor changes to tbb2017_20161128oss/build/linux.gcc.inc:
35,36c35,36
< CPLUS = g++
< CONLY = gcc
> CPLUS = g++-6
> CONLY = gcc-6
71c71,73
< CPLUS_FLAGS = $(ITT_NOTIFY) -g -O2 -DUSE_PTHREAD
> CPLUS_FLAGS = $(ITT_NOTIFY) -g -O3 -DUSE_PTHREAD -flto=8 -funroll-loops -ffast-math -march=native
> LINK_FLAGS += $(CPLUS_FLAGS)
> LIB_LINK_FLAGS += $(CPLUS_FLAGS)
this also seems to be true, without -flto and even when replacing -O3 with -O2 or even with a nearly original linux.gcc.inc (only compilers changed to version 6). Only when using libtbb_debug.so it is not crashing. BTW the code is clean regarding valgrind.
If your version of TBB precedes 4.4.6, please upgrade. TBB 4.4.6 is the minimal version that works with GCC 6.
Correct. Since TBB 4.4.6, the -flifetime-dse=1 option is added to the TBB makefiles.
