I would like to know if pthread_create is called each time when parallel_for or parallel_reduce is invoked.
Zhongze
Zhongze
Quoting - zhongzel@gmail.com
Nope. By the time parallel_for or parallel_reduce are invoked, the threads for TBB's use should have already been created. When you create the first task_scheduler_init object (if not declared deferred), one of the initialization steps is to create the worker thread pool. On Linux and MacOS machines, that's when pthread_create will be called.
