2485 Discussions
enumerable_thread_specific and nested parallel_for
Yaidel_R_
I'm working on the following problem: I need to iterate over a 3D grid and create 8 std::vector<TInfo>s, where TInfo instances represent a set of operations. This is kind of a coloring algorithm where each of the 8 vectors corresponds to a color, and all the TInfo instances in the same vector can be  processed concurrently without data races. This been said, I can do something like the following (not necessarelly valid c++ code):
[cpp]
std::vector<TInfo> tinfoVectors[8];
obtainTInfoVectors(grid,tinfoVectors); // This is a sequential procedure
for (int i = 0; i < 8; i++)
    parallel_for(blocked_range<size_t>(0,tinfoVectors.size()), FtorProcessTInfo(tinfoVector));
[/cpp]
I want to parallelize obtainTInfoVectors. This function goes through all the grid cells and creates 8 TInfo​ instances per cell, and pushes the instances into the right tinfoVectors. This means that in a multi-threaded implementation, different threads will try to add elements at the same time to tinfoVectors​ creating data races. Two solutions come to my mind:
  1. Replace std::vector with tbb::concurrent_vector: the problem is that obtainTInfoVectors​ very intensivelly adds elements to the vectors, and I don't really expect to have much gain using tbb::concurrent_vector. Thus, I discarded this option.
  2. To use tbb::enumerable_thread_specific to have a tinfoVectors per thread. This, I beleive, is more efficient.
Using  tbb::enumerable_thread_specific, the code can change to something like this:
[cpp]
typedef std::vector<TInfo> TInfoVectors[8];
enumerable_thread_specific<TInfoVectors> tinfoVecsTLS;
obtainTInfoVectorsParallel(grid,tinfoVecsTLS);
    for (t = tinfoVecsTLS.begin(); t != tinfoVecsTLS.end(); t++) //LOOP1
        parallel_for(blocked_range<size_t>(0,(*t).size()), FtorProcessTInfo((*t)));//LOOP2
[/cpp]
However, since parallel_for has some implicit synchronization, I'm afraid that LOOP1 can introduce unnecessary overhead. If I could flatten LOOP1 and LOOP2 into one loop and perform a parallel_for would be ideal. I'm aware of flattened2d​, but since it only supports forward iterator is not suited for parallel_for, and using parallel_do instead would result in unnecessary overhead also. So I'm thinking of make LOOP1 parallel as well, and get something like the following:
[cpp]
struct FtorProcessTInfoVecTLS{
    typedef enumerable_thread_specific<TInfoVectors>::const_range_type range_t;
    int i;
    FtorProcessTInfoVecTLS(int i_p)
    : i(i_p)
    void operator()(range_t & r) const {
        // the range only has one element
         parallel_for(blocked_range<size_t>(0,(*r.begin()).size()), FtorProcessTInfo((*r.begin())));//LOOP2
    parallel_for(tinfoVecsTLS.range(1), FtorProcessTInfoVecTLS(i),simple_partitioner());//LOOP1
[/cpp]
However, I'm not sure how nesting the parallel_for inside another parallel_for would work, nor if it is the best way to do it. Any comment or suggestions are very welcome.
Thanks in advance!
Anton_M_Intel
Hi, nesting works perfectly with TBB. If you are concerned about every last bit of the performance and the work is very small, use the same task_group_context for all parallel_fors
