2456 Discussions
error when compiling sample code with g++
lancekimbrough
I am beginning to work with the Threading Building Blocks and I'm having an issue compiling the sample program (sub_string_finder.cpp) with g++. However, when I use intel's c++ compiler, it compiles just fine.
To compile with g++, I execute:
g++ sub_string_finder.cpp -ltbb
and I get an error:
sub_string_finder.cpp:60: error: first argument of int main(size_t, char**) should be int
However, when I execute: icpc sub_string_finder.cpp -ltbb
it compiles just fine (and the compiled program works). I've never had any issues with GNU gcc (g++) before...so this is unexpected. Does anyone know what's going on here?
Thanks!
Lance
lancekimbrough
Well, I did some more searching around and seem to have found the problem...
Stricter requirements for function main signature
The two-argument signature for main has int as the first argument. GCC 4.3 rigorously enforces this.
int main(unsigned int m, char** c)
{ return 0; }
Gives:
error: first argument of 'int main(unsigned int, char**)' should be 'int'
Fixing this is straightforward: change the first argument to be of type int, not unsigned int. As transformed:
int main(int m, char** c)
{ return 0; }
So, I just changed line 60 in sub_string_finder.cpp to:
int main(int argc, char *argv[]) {
and it now compiles just fine with g++. Problem solved.
Wooyoung_K_Intel
Quoting - lance.kimbrough
{ return 0; }
Gives:
{ return 0; }
Thanks for reporting an issue. I checked 'sub_string_finder.cpp' and the version I saw has
'int main( int argc, char *argv[])' on line 60.
Could you tell us what TBB release you are using?
best regards
lancekimbrough
best regards
Well, I somehow ended up with TBB version 2.0 (tbb20_020_lin.tgz). Not sure how, as I just downloaded it a week ago. I just downloaded the most recent version on the site (version 2.1), and sure enough, line 68 now uses "int argc". Atleast it taught me something new about gcc. :) Thanks for the help.
Lance
