errors while compiling tbb
xinyuhou
I am totally new to tbb. Just followed the doc "getting started" and tried the parallel for example which works fine. When I tried to add tbb into my own project there were several compiling errers which will be listed in the end. All I did was just adding #include"tbb/parallel_for.h" and #include "tbb/blocked_range.h" into one of my cpp file where was the place I am gonna do parallel.
Thanks in advance
Jerry
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(44) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(44) : error C2059: syntax error : ','
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(53) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(53) : error C2059: syntax error : ','
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(59) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(59) : error C2059: syntax error : ','
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(65) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(65) : error C2059: syntax error : ','
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(71) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(71) : error C2059: syntax error : ','
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(92) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(93) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(94) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(110) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(92) : error C2059: syntax error : '{'
1> c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(135) : see reference to class template instantiation 'tbb::tbb_allocator' being compiled
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(92) : error C2334: unexpected token(s) preceding '{'; skipping apparent function body
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(93) : error C2059: syntax error : '{'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(93) : error C2334: unexpected token(s) preceding '{'; skipping apparent function body
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(94) : error C2059: syntax error : '{'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(94) : error C2334: unexpected token(s) preceding '{'; skipping apparent function body
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(110) : error C2059: syntax error : '{'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(110) : error C2334: unexpected token(s) preceding '{'; skipping apparent function body
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(182) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(183) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(185) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(182) : error C2059: syntax error : '{'
1> c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(192) : see reference to class template instantiation 'tbb::zero_allocator' being compiled
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(182) : error C2334: unexpected token(s) preceding '{'; skipping apparent function body
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(183) : error C2065: 'a' : undeclared identifier
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(183) : error C2056: illegal expression
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(183) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(183) : error C2473: '' : looks like a function definition, but there is no parameter list.
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_allocator.h(184) : error C2143: syntax error : missing ';' before 'template'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(153) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(153) : error C2059: syntax error : '='
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(153) : error C2238: unexpected token(s) preceding ';'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(158) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(158) : error C2059: syntax error : '='
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(158) : error C2238: unexpected token(s) preceding ';'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(168) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(168) : error C2059: syntax error : '='
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(168) : error C2238: unexpected token(s) preceding ';'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(171) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(171) : error C2059: syntax error : '='
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(171) : error C2238: unexpected token(s) preceding ';'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(153) : error C2059: syntax error : ','
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(158) : error C2059: syntax error : ','
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(168) : error C2059: syntax error : ','
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(171) : error C2059: syntax error : ','
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(204) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(215) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(218) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(224) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(227) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(229) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(230) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(204) : error C2059: syntax error : ','
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(215) : error C2059: syntax error : ','
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(218) : error C2059: syntax error : ','
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(224) : error C2059: syntax error : ','
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(227) : error C2059: syntax error : ','
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(229) : error C2059: syntax error : ','
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(230) : error C2059: syntax error : ','
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(267) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(274) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(284) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(286) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(288) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(290) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(293) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(302) : warning C4003: not enough actual parameters for macro 'throw'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(268) : error C2065: 'src' : undeclared identifier
1> c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(323) : see reference to class template instantiation 'tbb::movable_exception' being compiled
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(269) : error C2056: illegal expression
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(269) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(269) : error C2061: syntax error : identifier 'src'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(270) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(270) : error C2059: syntax error : 'constant'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(271) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(271) : error C2061: syntax error : identifier 'src'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(272) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(272) : error C2143: syntax error : missing ';' before '{'
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(272) : error C2334: unexpected token(s) preceding '{'; skipping apparent function body
1>c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(323) : fatal error C1075: end of file found before the left brace '{' at 'c:\\program files (x86)\\intel\\composer xe 2011 sp1\\tbb\\include\\tbb\\tbb_exception.h(120)' was matched
SergeyKostrov
Valued Contributor II
Quoting xinyuhou
1>c:\program files (x86)\intel\composer xe 2011 sp1\tbb\include\tbb\tbb_exception.h(44) : warning
syntax error : ','
1>c:\program files (x86)\intel\composer xe 2011 sp1\tbb\include\tbb\tbb_exception.h(53) : warning
syntax error : ','
Could you provide more technical details?What version of TBB is installed on your computer? WhatVisual Studio do you use?
I've looked at 'tbb_exception.h' header and on lines 44 and 53 ( andabove as well) I don't see any "wrong" codes
that could break the compilation ( TBB v4 Update 3 ).
Also, could you check if you have an STL file 'stdexcept' in '..\Include' folder of a Visual Studio? I think you have or
you would have an error '...can't open a file...' Anyway, please check.
Sergey
xinyuhou
Hi Sergey
I have no idea what is relevant to this issue, the only thing I did was just including 2 header file from tbb. And I compared the sample and my codemost of the stuff are the same except the example is developed on the console and mine is a window app.There is stdexcept filein the including folder of my vs2008.Theversion of tbb istbb40_297oss_win, guess it is relevantly new.
Thanks for the replying I am still working on this problem hope you can offer me more help
Thanks in advance
Jerry
SergeyKostrov
Quoting xinyuhou
Hi Sergey
developed on the console and mine is a window app...
I think you have a conflict between Windows headers and TBB headers and it is possibly related to are-defined
declaration of a'throw' method / function, or the whole class that is responsible for handling exceptions.
I would suggest two ways of investigating what could bewrong:
1. Create an empty Win32 Console project and start adding some components ( your headers andclasses, TBB headers,etc )
one at a time with a compilation after every addition / modification
2. Create an empty Win32Windows project and start adding some components ( your headers andclasses, TBB headers,etc )
Could you upload a test-project to reproduce the problem? Sorry, I can't suggest anything else and please keepus
informed on your progress.
Sergey
xinyuhou
Finally find where the problem is. Like Sergey said it because of the conflict defination of throw.
Thank you Sergey
Jerry
