I am create a node with 3 distinct inputs (of different data types), two of the inputs are optional in which case I will provide default value.
What is the correct way for handling default arguments in flow_graph's node ?
Kind regards
Thanks for posting in intel communities.
You can use join_node with distinct inputs for each port. You can create edges for these ports based on your use case.
Please refer to the below links for more details:
https://spec.oneapi.io/versions/latest/elements/oneTBB/source/flow_graph/join_node_cls.html
https://spec.oneapi.io/versions/latest/elements/oneTBB/source/flow_graph/join_node_policies.html
Thanks & Regards,
Noorjahan.
We haven't heard back from you. Could you please provide an update on your issue?
Thanks & Regards,
Noorjahan.
I have not heard back from you, so I will close this inquiry now. If you need further assistance, please post a new question.
Thanks & Regards,
Noorjahan.
