2486 Discussions
flow_graph error/exception handling in nodes ?
nyue
In the event of errors and exception in a node I am developing, what is the correct way to signify to the flow_graph runtime
  1. Errors
  2. Exceptions
Are there best practices for the above ? Any example code I can view ?
Kind regards
SeshaP_Intel
You can use exception handling in the flow graph to catch exceptions in the node.
You can modify the implementation of node, so that it catches the exception within its own body.
Please refer to the OneTBB Pro Textbook, page no:489 for more details.
Thanks and Regards,
Pendyala Sesha Srinivas
SeshaP_Intel
Thanks and Regards,
SeshaP_Intel
Has the information provided above helped? If yes, could you please confirm whether we can close this thread from our end?
Thanks and Regards,
SeshaP_Intel
Thanks for accepting our solution. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks and Regards,
