void graph_test2() { const int NPROC = 20; tbb::flow::graph g; tbb::flow::broadcast_node< tbb::flow::continue_msg > start( g ); std::vector< tbb::flow::continue_node< int > > workers; workers.reserve( NPROC ); std::vector<double> SUM( NPROC, 0. ); for(int i=0; i<NPROC; ++i) { auto work = [&, i](const tbb::flow::continue_msg &) -> int { double & sum = SUM; for(int k = 0; k < 1000000000; ++ k) { sum += k; } return i; }; workers.push_back( tbb::flow::continue_node< int > ( g, work ) ); tbb::flow::make_edge( start, workers ); } start.try_put( tbb::flow::continue_msg() ); g.wait_for_all(); }
I have 20-cores machine. I made a simple graph with 20 tasks to run in parallel. But graph runs only 19 tasks in parallel. 20-th core 100% occupied by wait_for_all(); It looks like waste of CPU resources. I use TBB 2017.2, Windows 7, MSVS 2015
Here is Amplifier's picture:
Hi Popov,
From documentation:
https://www.threadingbuildingblocks.org/docs/help/index.htm
void wait_for_all() Blocks until all tasks associated with the root task have completed and the number of decrement_wait_count calls equals the number of increment_wait_count calls. Because it calls wait_for_all on the root graph task, the calling thread may participate in work-stealing while it is blocked. |
Hi Maxim,
From the provided source code I would expect that the main thread should steal and process one task (inside g.wait_for_all()).
To understand why it's not happening we need to reproduce and investigate it locally. Please provide a full workable reproducer (including all includes and main() function).
BR, Oleg
Hi Maxim,
Thank you for the reproducer! It helped find the root cause of the problem, which is different task_arena entities used in worker and master threads.
As a workaround one should initialize TBB at first, e.g. via call to dummy parallel_for or via instantiation of task_scheduler_init class.
Regards, Aleksei.
Hi Aleksei,
Thank you for your reply! Good to know that there is no real problem, because in production code we use task_scheduler_init.
Regards, Maxim
