flow::graph : graph.wait_for_all() loads one core while do nothing usefull
Popov__Maxim
void graph_test2()
	const int NPROC = 20;
	tbb::flow::graph g;
	tbb::flow::broadcast_node< tbb::flow::continue_msg > start( g );
	std::vector< tbb::flow::continue_node< int > > workers;
	workers.reserve( NPROC );
	std::vector<double> SUM( NPROC, 0. );
	for(int i=0; i<NPROC; ++i) {
		auto work = [&, i](const tbb::flow::continue_msg &) -> int
			double & sum = SUM;
			for(int k = 0; k < 1000000000; ++ k) {
				sum += k;
			return i;
		workers.push_back( tbb::flow::continue_node< int > ( g, work ) );
		tbb::flow::make_edge( start, workers );
	start.try_put( tbb::flow::continue_msg() );
	g.wait_for_all();
I have 20-cores machine. I made a simple graph with 20 tasks to run in parallel. But graph runs only 19 tasks in parallel. 20-th core 100% occupied by wait_for_all(); It looks like waste of CPU resources. I use TBB 2017.2, Windows 7, MSVS 2015
Here is Amplifier's picture:
ali_n_
Hi Popov,
From documentation:
https://www.threadingbuildingblocks.org/docs/help/index.htm
void wait_for_all()
Blocks until all tasks associated with the root task have completed and the number of decrement_wait_count calls equals the number of increment_wait_count calls. Because it calls wait_for_all on the root graph task, the calling thread may participate in work-stealing while it is blocked.
Oleg_L_Intel
Hi Maxim,
From the provided source code I would expect that the main thread should steal and process one task (inside g.wait_for_all()).
To understand why it's not happening we need to reproduce and investigate it locally. Please provide a full workable reproducer (including all includes and main() function).
BR, Oleg
Popov__Maxim
Hi Oleg,
Full MSVS project attached.
BR, Maksim
Aleksei_F_Intel
Hi Maxim,
Thank you for the reproducer! It helped find the root cause of the problem, which is different task_arena entities used in worker and master threads.
As a workaround one should initialize TBB at first, e.g. via call to dummy parallel_for or via instantiation of task_scheduler_init class.
Regards, Aleksei.
Popov__Maxim
Hi Aleksei,
Thank you for your reply! Good to know that there is no real problem, because in production code we use task_scheduler_init.
Regards, Maxim
