Hi there!
In the transition from TBB "4.1" to "4.1 Update 1" something seems to have gone wrong.
Attached is a simple test case (inspired by http://software.intel.com/en-us/blogs/2011/09/14/how-to-make-a-pipeline-with-an-intel-threading-building-blocks-flow-graph).
The program is supposed to generate 100 numbers, let them be squared, and then print the square. The limiter node is set to an arbitrary limit of 7, to limit the number of numbers that are processed in parallel.
I use Visual Studio 2012 to compile this. With TBB V4.1 (20120718) and earlier versions, everything works fine: 100 numbers and their squares are printed. With TBB V4.1 Update 1 (20121003) the program stops after 8 numbers or so. It just terminates. This can be influenced by adjusting the limiter_node limit (7 in the example).
I have traced the problem back to the include file tbb/flow_graph.h: I can use both versions of the TBB DLL, but only the 20120718 version of tbb/flow_graph.h will produce the desired result.
For me, this is a showstopper. I have no idea how to work around this. Hope I've provided enough info! Thanks for any help or input on this - maybe I've just misunderstood the whole concept of a limiter_node :-)
Michael
- « Previous
- 1
- 2
- Next »
Hello, Michael,
Thank you very much for the report, and especially for the test case. The transition to scheduler bypass for flow::graph occurred between 4.1 and 4.1 update 1. There was a bug in the conversion of the code in continue_receiver. The fix is to apply the following patch to include/tbb/flow_graph.h:
Index: flow_graph.h
--- flow_graph.h (revision 9803)
+++ flow_graph.h (working copy)
@@ -234,6 +234,7 @@
my_current_count = 0;
task * res = execute();
+ if(!res) return SUCCESSFULLY_ENQUEUED;
return res;
I have attached the patch file to this message. (The ".h" at the end was to make it an allowable file type to upload.)
Again, thank you for the report. I am very happy that people are using the code.
Chris Huson
Hello Chris,
thanks a lot for the patch. Now the flow graph works flawlessly again!
Michael
hello,
the fix is also available in the 4.1 update 2
--Vladimir
Hi Vladimir,
no, I just looked. The patch posted by Christopher Huson has not made it into tbb41_20130116_oss_src.tgz :-( Sorry...
- Michael
oops sorry, my mistake. the build was done on 01/16 but the fix dated 01/18.
I see the fix has made it into V.1 Update 3 (tbb41_20130314) - thanks!
- « Previous
- 1
- 2
- Next »
