gcc 4.8.2 libs?
Oleg_V_
I'm trying to use tbb in Ubuntu. I'm using gcc from Ubuntu repository, version 4.8.2 But I have found that lib/intel64 folder contains only gcc4.1 and gcc4.4 subfolders. Should I just use gcc4.4? If it's compatible with gcc4.8.2?
Vladimir_P_1234567890
if you use exception_ptr you need to use gcc4.4. if you don't use it you can use any of both libraries. --Vladimir
Oleg_V_
Thanks, Vladimir!
