graph example from reference manual not compiling
gajendra_g_
Hi, I tried to compile the graph example as it is in the reference manual but it gives me an error.
Here is the code
#include <cstdio>
#include <iostream>
#include "tbb/flow_graph.h"
using namespace tbb::flow;
using namespace tbb;
struct body
    std::string m_name;
    body(const char *name) : m_name(name) {}
    void operator() (continue_msg) const
        std::cout << m_name.c_str() << "\n";
int main()
    graph g;
    broadcast_node <continue_msg> start;
    continue_node<continue_msg> a (g, body("A"));
    continue_node<continue_msg> b (g, body("B"));
    continue_node<continue_msg> c (g, body("C"));
    continue_node<continue_msg> d (g, body("D"));
    continue_node<continue_msg> e (g, body("E"));
    make_edge(start, a);
    make_edge(start, b);
    make_edge(a,c);
    make_edge(b,c);
    make_edge(c,d);
    make_edge(a,e);
    for(int i=0; i<3; ++i)
        start.try_put(continue_msg() );
        g.wait_for_all();
    return 0;
and here is the error.
In file included from ./firstExample.cpp:3:0:
/usr/include/tbb/flow_graph.h:1578:5: note: candidate: tbb::flow::interface8::broadcast_node<T>::broadcast_node(const tbb::flow::interface8::broadcast_node<T>&) [with T = tbb::flow::interface8::continue_msg]
     broadcast_node( const broadcast_node& src ) :
/usr/include/tbb/flow_graph.h:1578:5: note:   candidate expects 1 argument, 0 provided
/usr/include/tbb/flow_graph.h:1571:5: note: candidate: tbb::flow::interface8::broadcast_node<T>::broadcast_node(tbb::flow::interface8::graph&) [with T = tbb::flow::interface8::continue_msg]
     broadcast_node(graph& g) : graph_node(g) {
/usr/include/tbb/flow_graph.h:1571:5: note:   candidate expects 1 argument, 0 provided
It will be great to have clarification on the error.
Thanks in advance
Alexei_K_Intel
Thank you for the report. We will try to improve the example in one of the future releases.
I suppose the problem is that tbb::flow::broadcast_node always expects a graph reference to be passed to its constructor. Try to replace the line
with
broadcast_node <continue_msg> start(g);
Alex
Alexei_K_Intel
with
Alex
gajendra_g_
Dear Alex,
Thanks for the prompt reply even on a sunday. It will be really great to have examples in manual that compile when copied as such. My past experience with tbb has shown that the manual is not sufficient to learn, especially without the support from this forum.
Without good examples the learning curve becomes very steep.
But I hope to benefit from this forum and spread my knowledge on the fly as well.
Best
Gajendra
Alexei_K_Intel
Could you share what examples/functionality caused the learning/understanding problems, please? Your input can help us improve the documentation.
Alex
gajendra_g_
Hi Alex,
Missed this post. Sorry for delay in reply. I shared another example in another post which doesn't compile. To be very honest, I am new to TBB and am scourging the tutorials and reference manuals to get things straight.
without the corrections that you suggested in this post, I would never be able to compile my code unless I know the reference manual and each class member function of TBB. However with the corrections you suggested in this post , i still get an error in another example in the reference manual which apparently points to another object join of type join_node in the flow graph example 2 from the reference manual page 167
When i compile this example, compiler complains that object join doesn't have member function join_node::inputs()  . In this case i looked up the reference manual to check if indeed this was the case and it isn't true . There's a member function called inputs() (page 236) that returns reference to input_port_types.
I am not sure then what error am I making in my code. But it's consuming too much time to figure out  the error every time i try to compile examples :(
Best Gajendra
