It is either all or nothing.
Running tbb43_20150611oss/src/test/test_async_node.cpp reproduce the issue. Either the test will run to completion or will never complete. When the worker thread calls async_try_put() it does not always wake up the next node connected to it.
platform: linux_armv7_
tbb: tbb43_
Hello Marc,
how many core you are running the test on?
--Vladimir
Hello Vladimir,
Good question! I was running the test with only 1 core active. Running the same test with 4 cores did not reproduce the stall issue.
Marc
