hellp
luciano2
Boa tarde , estou pesquisando sobre uma placa mae intel H310 gostaria de saber se a mesma ja tem a função tpm 2.0 para colocar o windows 11 e se tiver qual nome e chamado no setup da bios?
ShivaniK_Intel
Thank you for posting your question.
We only provide support in English.I have translated your question.
<good afternoon , I'm researching on a board mae intel h310 would like to know if it already has the function tpm 2.0 to put windows 11 and if it has what name and called in the bios setup?>
Does this reflect your question correctly?
Thanks & Regards
Shivani
ShivaniK_Intel
As we didn't hear back from you could you please confirm whether the above response reflects your question?
Thanks & Regards
Shivani
ShivaniK_Intel
I have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Thanks & Regards
Shivani
