2486 Discussions
help to install TBB in visual studio 2010 with error
gaocheng073
Hi All,
I am trying to run the example with tbb. I got an error :
error MSB3073: commandcopy "\\ia32\\vc8\\bin\\tbb_debug.dll" "Debug\\"
:VCEndexitedcode 1C:\\Program Files\\MSBuild\\Microsoft.Cpp\\v4.0\\Microsoft.CppCommon.targets1136 Quicksor.
In my mind ,it may be about that I can not use TBB because I am a newer of newer .
Can you show me hou to use it with my studio clearly?
Any help is highly appreciated.
Gao Cheng
Vladimir_P_1234567890
hello Gao Cheng,
which version of tbb do you use?
do you compile an example inside the package tree?
Examples in latest version should work in above conditions
Also you can try to setTBBROOT environment variable pointing to tbb installation folder.
--Vladimir
SergeyKostrov
Valued Contributor II
>>...error MSB3073: command copy "\ia32\vc8\bin\tbb_debug.dll" "Debug" ..
VS's MsBuildattempted to execute an MS-DOS command 'copy' and itfailed because some problem:
- with the path to 'tbb_debug.dll', or
- with the path to 'Debug' folder, or
-with both.
>>...Can you show me how to use it with my studio clearly?..
Did you setup aTBB environment with VS 2010? Please take a look at "Getting Started" with TBB
pdf-document. It is enclosed.
Sergey
SergeyKostrov
Hi Gao,
Finally I had some time tolook at the issue and I reproduced the sameerror with Visual Studio 2005.
It looks like you didn't compile TBB's'Debug' configurationDLL 'tbb_debug.dll'. In my environment
all paths are correct, but 'copy' command failed because it couldn't find 'tbb_debug.dll'. So, as soon as
I compiled theDLLMsBuild was able to build a TBB-based application.
Sergey
gaocheng073
hello,Sergey
Thanks for your replay.
Yes , I setup a TBB environment with VS 2010,ok ,I will try ,
AndI want to ask you why whenI put my project in the 'my project',it has no error,but when I run it it say "the application failed to initialize properly oxc0150002"
Thanks for your help ,
Looking forard to your replay!
gaocheng
gaocheng073
hello sergey
I am sorry to tell you I do not know about "compiled the DLL MsBuild was able to build a TBB-based application" and I must not do that ,I do not know how to do it , Can you tell me again?
Waiting for your replay!
gaocheng
SergeyKostrov
You need to compile TBB's mainDLLs for Debug and Release configurations. A project for Visual Studio 2005
is located at:
Note: I assume that you have version 4 of TBB
..\TBB40\Build\vsproject\tbb.vcproj
Open the project and compile Debug and Release configurations of TBB's main DLLs:
Debug : tbb_debug.dll
Release: tbb.dll
Sergey
SergeyKostrov
>>...when I run it it say "the application failed to initialize properly oxc0150002"...
Hi Gao,
You've provided a very limited information and it is really hard to understand what is going on. It looks like the application simply can't load some DLL.
I even don't know what version of TBByou've installed. Please provide as more as possible technical details next time.
Sergey
mvvardhan
I report the following error when I try to run a C++ program developed using OpenCV withMicrosoft Visual Studio 2005 Version 8.0.50727.867. How do I fix this error?
The program cant start because tbb.dll is missing from your computer. Try reinstalling the program to fix this problem.
Thank you.
Vishnu
Vishnu Vardhan Makkapati
Senior Scientist, Philips Research Asia - Bangalore
Philips Innovation Campus, Philips Electronics India Limited
Manyata Tech Park, Nagavara
Bangalore - 560 045, Karnataka, India
Phone: +91-80-41892241, Fax: +91-80-41892265
E-mail: vishnu.makkapati@philips.com
Intranet: pww.research.philips.com
Internet: www.research.philips.com
SergeyKostrov
>>...How do I fix this error?
>>fix this problem...
Hi Vishnu,
Take a look at Post #7 for more technical details.Here is a quote:
Studio 2005 is located at:
Release: tbb.dll
-You're trying to execute a Release version of your application andthe'tbb.dll' has to be in a
search path of the operating system ( environment variable PATH ), or put a copy to a '..\Release' folder;
- If you're trying to execute a Debug version of your application the'tbb_debug.dll' has to be in a
search path of the operating system ( environment variable PATH ), or put a copy to a '..\Debug' folder;
- Try to use MS Depends utility( enclosed ) to verifythat all dependent DLLs ( OpenCV, CRT DLLs,
etc )could be loaded, in another words, could be found by the operating system.
Sergey
