I was trying to compile a boost+Intel TBB code using intel compiler (ICC-13.0.1) The TBB library is latest (4.2) and boost is 1.55.0. The code incorporates C++11 features and so I use the std=c++11 flag
I am getting this error:
icpc: error #10104: unable to open 'tbb_pLaCeHoLdEr'
make: *** [driver.o] Error 1
My Makefile contents are as follows:
INCLUDE_PROJECT = /home/aniketnp/multiproc/
INCLUDE_BOOST = /home/aniketnp/boost_1_55_0/
TBB_L = /home/aniketnp/tbb42_20140122oss/lib/intel64
TBB_I = /home/aniketnp/tbb42_20140122oss/include
CXXFLAGS = -I$(INCLUDE_PROJECT) -I$(INCLUDE_BOOST) -I$(TBB_I) -L$(TBB_L) -tbb -lpthread -std=c++11
Could any body speculate what could be the possible error?
1. The boost and TBB are in my home directory.
2. The ICC13.1 is loaded through a module in our cluster.
3. The LD_LIBRARY_PATH variable correctly shows the TBB_L variable in makefile (properly exported in the .bashrc file.
