2456 Discussions
infinite loop during tbb::task_scheduler_init on Q9550 CPU and Win7 64bit
baranc3k
I have detected infinite loop on latest tbb( version 20090809) during initialization of task_scheduler_init.
During initialization of TBB, __intel_fast_memset is calling and this function is in infinite loop:
see disassembly __intel_fast_memset:
0261C720 test dword ptr [___intel_cpu_indicator (262B7D4h)],0FFFFFE00h
0261C72A jne __intel_fast_memset.J (261C700h)
0261C730 test dword ptr [___intel_cpu_indicator (262B7D4h)],0FFFFFF80h
0261C73A jne __intel_fast_memset.H (261C710h)
0261C740 test dword ptr [___intel_cpu_indicator (262B7D4h)],0FFFFFFFFh
0261C74A jne __intel_fast_memset.A (261C6E0h)
0261C750 call ___intel_cpu_indicator_init (261D2A0h)
0261C755 jmp __intel_fast_memset (261C720h)
0261C757 mov esi,esi
0261C759 lea edi,[edi]
This bug is dependent on OS and CPU. It's reproducing only on this configuration:
Windows 7 64bit
Intel Core 2 Quad Q9550 2.83GHz
family=6, model=7, stepping A, ext.family=6, ext.model=17, revision=E0
Is not reproducible on identical processor with different stepping and revision.
Problem is in some test of results from cpuid instruction (called from ___intel_cpu_indicator_init)
I have VS 2008 sp1 compiler.
Previous version of TBB works well.
Test file:
#include "tbb/task_scheduler_init.h"
tbb::task_scheduler_init tbb_init;
int _tmain(int argc, _TCHAR* argv[])
return 0;
Does anybody know what is problem, or has anybody same problems?
ARCH_R_Intel
I found out that the issueis known. Yes, it is stepping specifc.The issue has been corrected in the latest release ofthe Intel 11.1 compiler. So what you need is a TBB library built with the fixed compiler.
I think that TBB 2.2 update 1 (build 010), which was released around 2009-Oct-15, was built with the fixed compiler. But I'm still asking around to make certain.
RafSchietekat
Black Belt
I myself would never think of using a task_scheduler_init as anything other than an automatic variable.Maybe the problem just goes awayif you move the instance into main()'s body?
baranc3k
Quoting - Raf Schietekat
Without success, initialization inside "main" freeze too.
It only happens in release, debug runs correctly.
RafSchietekat
Black Belt
"Without success"
OK, then I hope that somebody familiar with this setup will be able to assist.
baranc3k
"Without success"
Thanks for help
ARCH_R_Intel
I'd like to try to reproduce the problem here, as it sounds like a generic problem in __intel_fast_memset. Are you using a binary of tbb.dll that you built or that was supplied by Intel?
ARCH_R_Intel
Vladimir_P_1234567890
Yes, TBB 2.2 update 1 comm-aligned release should have a fix. There is also win7 support added officially.
--Vladimir
baranc3k
--Vladimir
Yes, I have binaries from intel.
I'm amazed for prompt answers and solutions from all.
Thank you very much.
--Ivan
