internal compiler error
chowdhary__sangeeta
Hello Everyone,
I am trying to build tbb program with parallel_for
 tbb::parallel_for(
    tbb::blocked_range<int>(0,len),
    [&](tbb::blocked_range<int> &r, size_t thdId) {
        for(int i = r.begin(), i_end = r.end(); i < i_end - 1; i++) {
            for (int j = 0; j < len ; j += 1) {
                a += a[i + 1];
I am building it using g++ on 64-bit linux machine with version 5.4. I am getting this error while building it
 internal compiler error: in expand_expr_real_1, at expr.c:9608
                 a += a[i + 1];
Any help would be appreciated.
Alexey-Kukanov
The body of parallel_for should only have one parameter, in your case - a blocked_range. The second parameter - size_t thdld - should be removed.
