mutable and thread safety
robert_jay_gould
This is probably notnecessarilyTBB related, but can an tbb::atomic or a tbb::mutex be mutable?
I have this const function, that calls some of my code (can't change the caller), that reads data out from an object.But internally during this call I need to ensure that the data is not being changed by another thread, so I was placing a scoped lock in the call, problem is locking/unlocking require the object to not be constant, since the lock is part of the object. So I'm not sure if I should cast away the the constness of the entire object within the callback, or if its possible to make thesynchronizationprimitive mutable (keyword).
Dmitry_Vyukov
Valued Contributor I
I don't see any problems in declaring mutex or atomic as mutable. Also you can cast away the constness only from mutex before locking.
robert_jay_gould
Quoting - Dmitriy Vyukov
Thanks, I wasn't sure if mutable might have some sort of effect on handling and loading the values in the registers.
ARCH_R_Intel
In almost all cases, const gives code generators no useful information and consequently has no effectonlow-level code generation. The reason is twofold:
  • const can be cast away
  • const does not prevent modification via other pointers to the same target location
If the compiler can prove these two reasons do not apply, it has enough information to do the optimization anyway without the const. The few signifcant contexts where an optimizer can exploit const are:
  • The const is on the original object declaration, and thus the object is known to be immutable over its lifetime modulo any mutable keywords.
  • The const is on the target of a pointer marked restrict (C99), and thus is known to be immutable over the scope of the pointer. [I'm begin deliberately vague about "scope" - see C99 standard for details.]
