odd behavior on simple program (factorials)
lancekimbrough
I'm trying to get a grasp of TBB, so I started out by writing a simple program to calculate the factorial of i, from i=0 to n. I've been working with the GNU MP (bignum) library, so I decided to use it as well to handle the large factorials. I'm really just looking to get a simple program to behave properly...but I'm having some difficulties with it. When I run the following code (printing out the "i" in the parallel loop), I get some very strange results....
[cpp]#include
#include
#include
#include
#include "tbb/task_scheduler_init.h"
#include "tbb/blocked_range.h"
#include "tbb/parallel_for.h"
using namespace tbb;
using namespace std;
class factorial {
public:
void operator()( const blocked_range& range ) const {
// mpz object to store factorial
mpz_class fact_result;
for( double i=range.begin(); i<=range.end(); i++ ) {
// perform factorial on i
mpz_fac_ui(fact_result.get_mpz_t(), i);
cout << i << "n";
// define function ParallelFactorial
void ParallelFactorial(int n) {
// new factorial object called fact
factorial fact;
parallel_for( blocked_range(0, n, 1000 ), fact );
int main() {
task_scheduler_init init;
// Max number to apply factorial
int b=5000;
clock_t start = clock(); // start clock for parallel test
ParallelFactorial(b); // apply parallelfactorial up to b
clock_t end = clock(); // find end time for parallel test
double time_elapsed = double(end-start)/CLOCKS_PER_SEC; // calculate elapsed time in parallel
cout << "time to run in parallel: " << time_elapsed <<"n";
/*-----------------------------begin serial test-------------------------------------*/
clock_t start_serial = clock(); // start clock for serial test
mpz_class fact_result_serial; // mpz object for storing serial factorial
for (int i=0; i<=b; i++ ){
mpz_fac_ui(fact_result_serial.get_mpz_t(), i); // perform factorial on i
//cout << i <<"n";
clock_t end_serial = clock(); // find end time for serial test
double time_elapsed_serial = double(end_serial-start_serial)/CLOCKS_PER_SEC; // calc elapsed time in serial
cout << "time to run in serial: " << time_elapsed_serial <<"n";
double time_speedup=time_elapsed_serial/time_elapsed;
cout << "time speedup: " << time_speedup;
return 0;
[/cpp]
When I run this particular code (with b=5000), my return is
4680
4994
4681
4682
4995
4996
4997
4998
4999
5000
4683
4684
4685
4686
4687
time to run in parallel: 1.22
time to run in serial: 1.12
time speedup: 0.918033
Why is the progression of i so erratic? I'm guessing it has something to do with the multiple threads....am I missing something more fundamental here? I'm not sure what else to try? I appreciate any help.
Lance
RafSchietekat
Valued Contributor III
"Why is the progression of i so erratic?" TBB recursively divides the range to find parallelism, like you'll see visually in the tachyon example. BTW, you include the end() of a blocked_range in the loop, which you shouldn't (neither in STL nor in TBB), but I'll leave it at that.
RafSchietekat
Dmitry_Vyukov
Quoting - lance.kimbrough
What progression do you expect? And what is wrong with this progression?
lancekimbrough
Well, I guess there really is nothing wrong with it, lol. I suppose I've been working in "serial" mode for so long that I didn't expect to see the "i" jumping around, but with multiple threads, it makes perfect sense. And Raf, I appreciate you letting me know not to include the end() of the blocked_range in the loop. I've never worked with the STL or any template library before, so I'm learning as I go. I still have much to learn :) Thanks again for the input!
Lance
