2456 Discussions
oneAPI tbb + fopenmp: just one core used?
tayttttt
Edit: NVM I missed some OMP environment variables
consider the following toy program:
#include <iostream>
#include <tbb/global_control.h>
#include <tbb/parallel_for.h>
#include <tbb/enumerable_thread_specific.h>
int main(int argc, char *argv[]) {
  tbb::global_control gc{tbb::global_control::max_allowed_parallelism, 8};
  tbb::enumerable_thread_specific<long long> sum;
  for (int it = 0; it < 5; ++it) {
    tbb::parallel_for(0, 500'000'000, [&](const int i) {
                                        sum.local()++;
  std::cout << "---" << std::endl;
  for (auto i : sum) { std::cout << i << std::endl; }
Compiling this program with
g++ test.cc -ltbb
 Produces a program that uses 8 cores / 8 threads. However, if g++ is called with an additional fopenmp flag:
g++ test.cc -ltbb -fopenmp
The program runs approx. 7 times slower since it only uses one core / 2 threads.
Why does this happen? Is oneAPI TBB incompatible with OpenMP?
(I'm using GCC 11.1.0 and oneAPI TBB 2021.2.0)
Thank you!
NoorjahanSk_Intel
GCC 11.1.1 version support has been enabled with oneTBB 2021.4 version, so could you please try with the latest version of oneTBB 2021.4?
Refer to the below link for more details:
https://www.intel.com/content/www/us/en/developer/articles/release-notes/intel-oneapi-threading-building-blocks-release-notes.html
Please do let us know if you still face any issues along with the OS version being used.
I tried with the latest version(2021.4) of Intel oneTBB and g++ (9.3) on Ubuntu and observed that it is utilizing 8threads/cores even with
-fopenmp option included while compiling the code.
Please refer to the attached screenshot for more details.
Thanks & Regards,
Noorjahan.
NoorjahanSk_Intel
We haven't heard back from you. Could you please provide an update on your issue?
Thanks & Regards,
Noorjahan.
NoorjahanSk_Intel
I have not heard back from you, so I will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Thanks & Regards,
Noorjahan.
