I am trying to learn how to traverse a tree using parallel_do. The following is the code that I currently have, and I am would like to fix a few problems that I see with it. The problems are:
a. This program requires global variables. Is there an alternative to using globals? In other words, is it possible to send some extra parameters to the overloaded operator()? When I tried, it gave too many errors that I could not fix.
b. Doing multiple types of parallel operations using the following code looks impossible as the class Node itself is overloaded with the operator (). I tried moving it into the body of BST, but ended up with many errors. Is there a way out?
c. How to terminate parallel_do prematurely?
Here is the code:
[cpp]#include#include "tbb/task_scheduler_init.h" #include "tbb/parallel_do.h" #include "tbb/concurrent_queue.h" #define N 12 using namespace std; using namespace tbb; int X; concurrent_queue CQ; class Node { public: int data; Node *left; Node *right; Node() : left(NULL), right (NULL) {} typedef Node *argument_type; void operator()( argument_type c_Node, parallel_do_feeder &append_task ) const { /* * Uncomment the following return to print (not find?) address of only one node */ if ( ! CQ.empty() ) { //return; } if ( c_Node == NULL ) { return; } if ( c_Node->data == X ) { printf (" %pn", (void *) c_Node); if ( CQ.empty() ) { // concurrent_queue is used for thread-safe handling CQ.push(true); } } append_task.add( c_Node->left ); append_task.add( c_Node->right ); } }; class BST { private: Node *head; public: BST(int x); void ins(int x); bool trav_find(int x); }; BST::BST(int x) { head = new Node; head->data = x; head->left = NULL; head->right = NULL; printf("New BST (head = %p, data = %d)n", (void *) head, x); } void BST::ins(int x) { Node *c_Node = head; bool inserted = false; while ( ! inserted ) { if (x <= c_Node->data) { if ( c_Node->left == NULL ) { Node *n_Node = new Node; n_Node->data = x; c_Node->left = n_Node; printf (" %d is left of %dn", x,c_Node->data); inserted = true; } else { c_Node = c_Node->left; } } else { if ( c_Node->right == NULL ) { Node *n_Node = new Node; n_Node->data = x; c_Node->right = n_Node; printf (" %d is right of %dn", x,c_Node->data); inserted = true; } else { c_Node = c_Node->right; } } } } bool BST::trav_find(int x) { X = x; // sets the value to be searched as a global CQ.clear(); Node *ary[] = { head }; parallel_do(ary, ary+1, Node()); return (! CQ.empty()); } int main() { task_scheduler_init init(4); BST my_tree(N/2); for (unsigned int i=0; i<< endl; for ( int i=0; i<10; i++ ) { if ( my_tree.trav_find(i) ) { printf (" %3d : presentnn", i); } else { printf (" %3d : absentnn", i); } } return 0; } [/cpp]
The modified code is:
[cpp]#include
#include
#define N 10
class Node {
public:
int data;
Node *left;
Node *right;
class BST {
private:
Node *head;
int sX; // we shall search this number
concurrent_queue*CQ;
public:
BST(int x);
void ins(int x);
bool trav_find(BST &bst, int x);
void operator()( argument_type c_Node, parallel_do_feeder&append_task ) const
return;
if ( c_Node->data == sX ) {
if ( (*CQ).empty() ) {
(*CQ).push(true);
BST::BST(int x)
head = new Node;
head->data = x;
head->left = NULL;
head->right = NULL;
CQ = new concurrent_queue;
n_Node->data = x;
inserted = true;
} else {
} else {
n_Node->data = x;
inserted = true;
} else {
bool BST::trav_find(BST &bst, int x)
sX = x; // sets the value to be searched
(*CQ).clear(); // if this is not empty, then at least once the element was found
parallel_do(ary, ary+1, BST(bst));
return (! (*CQ).empty());
int main()
BST my_tree(N/2);
if ( my_tree.trav_find(my_tree, i) ) {
} else {
return 0;
[/cpp]
Yes, I did use a similar solution (as in the commented return in the original version of the program). But the problem is that all the added tasks scheduled to run will first have to run to terminate. Some overhead that I don't know if be can avoided...
I had similar problem with parallel_while too. Even after finding and even with explicit entry level check of the success it would still execute all the threads. A more fundamental way to control spawning of threads might have been better but parallel_while was depreicated anyway. It's just that such a memory makes me feel very cautious about setting up an extra counter, shared may be, as the overhead of starting a thread itself does not appear to be all that negligible.
When you cancel a thread you don't know in what state it is. It might be holding a lock or other resources.
Obviously, there can be some specific situations where using the pthread_cancel() function is safe and justified, but in general it is rude to kill someone just because you don't need his work anymore. ;-) It's better to just let him know, he can finish his job and let him make the things up on his own, e.g. deallocating the memory or releasing other resources.
So, by analogy, I don't suppose there is or will be an analog of the cancel() function for TBB - it would encourage bad programming practices.
I guess you are right there, the same thought was bothering me too. I was thinking in terms of a suicide-destroyer. But that's just some crazy thought. :P
Sinedie, I think what you're looking for in TBB is called the task_group_context, which will provide a group of tasks that can be cancelled together. Tasks that are currently executing would continue but there's so little work done in the BST functor that there should be no big delays there. It does seem to be rather creative overkill to use a concurrent_queue to hold the termination token when a simple global bool would suffice. However, this whole code snippet seems incomplete (what's "for(unsignedinti=0;i<
But definitely something on the order of a pthread_cancel() is out of the question: we're working with tasks here, not threads; we want to reuse our threads as much as possible since it's much more expensive to create and destroy them than it is for tasks.
Why not simply change your iterator?
[cpp]intptr_t searching; // ~0==searching, 0==found/stop searching Node* found; // 0==not found, x==found node ... if ( (c_Node & searching) == NULL ) { return; } if ( c_Node->data == X ) { found = c_node; searching = NULL; return; } [/cpp]
Remove the concurrent queue to hold the return (found) node. Return it back through the iterator.
Note, if multiple hits occur during the narrow window of finding X and setting searching=NULL then wouldn't the subsequent find be equally important as the first thread to find?
Jim
I haven't read the code carefully, before. Wouldn't it be better to add only one son of the node by the feeder (say, the right one) and process the other one in the same task - in a while or do...while loop ?
This would be the better route, as you traverse one leg direction spawn task(s) for the other leg direction (not both directions). This will halve the app code to TBB requests.
JD
