suppose we have a container C of objects T, C<T> and T is non-copiable, deriving from boost::noncopiable, and some tbb::parallel_do calls:
[cpp]
C<T> container;
tbb::parallel_do(container.begin(), container.end(), ...);
[/cpp]
or suppose we have an abstract base class B:
[cpp]
boost::ptr_vector<B> container;
[/cpp]
These don't compile as Item, so T or B, is copied in do_iteration_task, there is an "Item my_value". It should be "Item& my_value" but I understand this violates the whole design, as you can feed objects to a tbb::parallel_do while it's still running so objects must (?) be part of internal tasks. I'm not a big fan of that but fine, even if I haven't spotted this limitation in any documentation.
BUT this doesn't justify tbb::parallel_for_each to fail. It's currently implemented using tbb::parallel_do that has this constraint, so you cannot use it with non-copiable items or complex containers like boost::ptr_* BUT tbb::parallel_for_each doesn't need to copy object.
Can we have it reimplemented in terms of tbb::parallel_for? Or possibly have the limitation in tbb::parallel_do removed?
At affects al least any TBB version <= 4.1.
Thank you.
Stefano
