I have a rather large program which stores pointers to objects in a list. I thought of using parallel_for_each to process each object in the list.
So tried a small program:
The program outputs all 10000 values of i without any problem.
As far as I read about parallel_for_each, it is supposed to always requires random access iterators. But std::list does not support random access iterators. Then how did my program work?
I've even seen the internals of how parallel_for_each is implemented (you use a parallel_do and spawn tasks). The do_task_iter class uses Iterator middle = my_first + k/2; and as I understand, the value held by 'Iterator middle' may become erroneous if it isn't a random access iterator? Correct?
So can I use std::list with parallel_for_each or not?
[cpp]#include #include#include using namespace std; using namespace tbb; class Item { int i; public: Item() {} Item(int ii):i(ii) {} Item(const Item& old) {i = old.i;} void doSomething() {printf("Whoopee I'm doing something! %d\n",i);} }; class Doer { public: Doer() {} void operator()(Item* item) const//INFO: program won't work without this const { item->doSomething(); } }; int main() { list
- v; for(int i=0;i<10000;++i) v.push_back(new Item(i)); Doer d; parallel_for_each(v.begin(), v.end(), d); }[/cpp]
Yes you can.
parallel_for_each minimally requires input iterators. It's parallel_for that requires random access iterators.
Yes you can.
