I try to use boost::bind instead of lambda function as the compiler is not 4.7.
got the following error. any way to solve it?
test.cpp: In member function void list::parallel():
test.cpp:27: error: no matching function for call to parallel_for(__gnu_cxx::__normal_iterator > >, __gnu_cxx::__normal_iterator > >, size_t, boost::_bi::bind_t, boost::_bi::list2<:_BI::VALUE>
- , boost::arg<1> > >)
using namespace std;
struct Obj
int32_t value;
class list
std::vector objList;
public:
void process(Obj& obj)
//do something
void parallel()
tbb::parallel_for(objList.begin(), objList.end(), size_t(1), boost::bind(&list::process, this, _1));
int main(int argc,char *argv[])
return 1;
The first mistake is not related to bind:iterators are passed directly to the parallel_for. It accepts either numeric types or a Range-modelling type (e.g. blocked_range). The second, an iterator is not implicitly convertable to its reference_type which is expected in list::process.
Please try the following:
void process(std::vector::iterator it) ...tbb::parallel_for(tbb:blocked_range<:VECTOR>::iterator>(objList.begin(), objList.end()),boost::bind(&list::process, this, _1)
list::process() expects a reference to Obj, but the result of boost::bind() will get an iterator to Obj from tbb::parallel_for, so you'll have to dereference it first?
ok I try to modify it to accept iterator. However, no luck.
test.cpp:52: error: no matching function for call to parallel_for(__gnu_cxx::__normal_iterator > >, __gnu_cxx::__normal_iterator > >, size_t, boost::_bi::bind_t > > >, boost::_bi::list2<:_BI::VALUE>
void process(std::vector::iterator obj)
//do something
"The first mistake is not related to bind:iterators are passed directly
Range-modelling type (e.g. blocked_range)."
Ah, I hadn't looked at the implementation yet: there's some code that doesn't work with iterators, but maybe compiler diagnostics in the presence of SFINAE just doesn't drill through to that underlying reason even if there's no remaining specialisation?
So it might work with a Range and the revised process().
(Edited)
(Edited)
Thank you.
Just a small modification to make it work.
void process(const tbb::blocked_range<:VECTOR>::iterator>& r) const;
