I am a relative newbie to Threading Building blocks and I have been trying to implement some code whose both versions I understand logically but I am not sure why one is throwing an exception while the other one is not.
I was using parallel_reduce to implement the summing of all elements of the a float array. Well. Here is the code for the parallel summer class.
class
ParallelSummer{
public:ParallelSummer(
float* arr) {this->arr = arr;sum = 0;}ParallelSummer(ParallelSummer& parsum, split) {sum=0;}
void join (ParallelSummer& parsum){sum+=parsum.sum;
long double get_sum(){return sum;} void operator()(const blocked_range<float*>& range){ long double local_sum = sum; float* end = (float*)range.end(); for(float* i=range.begin();i!=end;++i){local_sum+=*i;
sum = local_sum;
private: float* arr; long double sum;};
long double ParSum(float* arr, size_t n)
ParallelSummer parsum(arr);
parallel_reduce(blocked_range//parallel_reduce(blocked_range<
long int>(0,n,n/8),parsum); return parsum.get_sum();}
Well this code works fine and I get speedups of about 2-3X and sometimes higher. What I dont understand is why the following sample does not work and gives me an exception.
void
operator()(const blocked_range<long int>& range){ long double local_sum = 0; long int end = (long int)range.end(); for(long int i=range.begin();i!=end;++i){local_sum+=arr;
sum = local_sum;
long
double ParSum(float* arr, size_t n){
//parallel_reduce(blocked_rangeparallel_reduce(blocked_range<
Am I missing something here ?
Thanks in Advance,
Pranav.
In your splitting constructor, you did not initialize arr. And later in operator() you dereference a pointer that contains some garbage, thus getting an exception.
In the blocked_range
That was indeed very silly of me.
Pranav.
