I am trying to do some testing with parallel_for. I tried a simple test program and parallel_sort actually 50% slower than regular sort. I tried this on Linux 2.6.28 with gcc 4.3.3 compiler. I ran the test on two different machines (one with 2 cores and one with 4 cores). If I look at cpu consumption, parallel_sort actually engages all cpus 100% while the regular std::sort only uses one cpu. So I am not sure whats happening. Is there something wrong with my program.
I am pasting the code here. Let me know thanks?
#include "tbb/parallel_sort.h"
#include "tbb/task_scheduler_init.h"
#include "tbb/tick_count.h"
#include
#include
using namespace tbb;
using namespace std;
int main(int argc, char * argv[])
task_scheduler_init init;
srand(time(NULL));
ulong num_ele = 10000000;
if (argc > 2)
num_ele = boost::lexical_cast(argv[2]);
cout << " Sorting " << num_ele << " longs " << endl;
long *elements = new long[num_ele];
cout <<"Initializing random data. " << endl;
for (ulong i=0; i < num_ele; ++i)
elements = ((ulong)rand() << 32) + rand();
tick_count t0 = tick_count::now();
if (argc > 1 && *(argv[1]) == 'r' )
cout << "Doing single threaded std::sort" << endl;
std::sort(elements, elements + num_ele);
else
cout << "Doing Parallel Sort" << endl;
parallel_sort(elements, elements + num_ele);
tick_count t1 = tick_count::now();
cout << "Time took to sort " << (t1 - t0).seconds() << " secs " << endl;
delete [] elements;
#include
#include
srand(time(NULL));
if (argc > 2)
else
delete [] elements;
You might use an older TBB version. Update to a newer version, e.g. the last commercial-aligned release corresponding to TBB 2.1 Update 4.
Here are the results on my Intel Core 2 Quad Q6600 and the stable release (I added the number of threads when initializing the task scheduler):
serial: 2.545 secs
parallel, 1 thread: 3.68352 secs
parallel, 2 threads: 1.93752 secs
parallel, 4 threads: 1.07267 secs
So, it's clearly faster, but the speedup is not stunning.
There seem to be a large overhead for starting the threads. For a larger problem (like lasting a few minutes) the difference should be more encouraging.
Best regards
serial: 2.545 secs
Best regards
Quoting - Alexey Kukanov (Intel)
I was using the latest release. Anyway its working great now. I get ~50% better performance. I am not sure what was wrong before. Completely puzzled. Quite sure I did somethign something stupid in my old runs (like linking to debug lib). Anyway thanks for prompt response.
While searching the forums, I found a similar issue reported by another user. It seems like you have identified it as Windows Specific. Do you know if there are any fixes to that issue?
THanks
mSR
Quoting - bartlomiej
serial: 2.545 secs
Best regards
serial: 2.545 secs
Best regards
I tested with array of 500M longs on Quadcore and there is substantial improvement (66 sec Vs 26 sec).
On DualCore with 40M elements I can get around 50% improvement (45 sec Vs 30 Sec).
Quoting - msr999
Yes, there was an earlier problem and we fixed it in an update to TBB 2.1. That's why I supposed you might have had an older version, and recommended you to update. If you use the last 2.1 update, you have the fix.
