hii all. iam a student. i implemented the parallel version of kruskal using tbb as a project. iam attaching the code files. now the problem i hav is wen the number of nodes is greater than 300 the the edges and weights of the edges are changing to 1. i.e., after calling parallel_sort function in kruskalApply function. i donno the reason :( it works fine for small number of nodes. iam intrested in any suggestions as well. thankyou
