pipeline pulus parallel for
Xingjing_Lu
hi,
in my app, I want to parallelize it with pipeline and parallel for. Each stage characters serial(There are dependence between different items of the same stage), and in each stage, I want to process the data in parallel, now, I do it with parallel_for. But it seems does not work.
My questions are: TBB does not support task parallelism in producer-consumer patter. So, how should I do it?
stage1 // serial
parallel_for
parallel_for
stage2 // serial
parallel_for
stage3 // serial
Alexey-Kukanov
Xingjing Lu wrote:
In the above example, I set the Number of threads to execute the pipeline like below:
pipeline.run(TheadNum); // ThreadNum = 3, the same number as the number of stages.
If I set up the task schedule for each parallel_for in different stages as:
task_scheduler_init init(4);
parallel_for( blocked_range<int>(0, 4), PASSIN);
what will happened to stages and parallel_for, are there 3 threads for each stage, and another 4 threads for each parallel_for? or there are only 3 threads totally?
It's a common mistake to think that the argument to pipeline.run() is the number of threads. It's not; it's maximal number of items that are allowed to flow through the pipeline at a time. And the motivation for this argument is not restricting concurrency but bounding resource usage (which could otherwise grow "over the top" when a serial filter is the bottleneck in the pipeline).
So if you instruct the task scheduler (via task_scheduler_init) to use 4 threads, that's what you will get (unless the scheduler was initialized earlier, possibly implicitly), no matter what token limit is set for pipeline.
RafSchietekat
Valued Contributor III
I'm not sure I understand, but you should not have a problem calling parallel_for() from within a (parallel_)pipeline stage.
Are you saying that it works with a serial loop but not with a parallel loop, or is it something else?
jimdempseyatthecove
Xingjing Lu wrote:
hi,
stage1 // serial
parallel_for
parallel_for
stage2 // serial
parallel_for
stage3 // serial
I think you want something like:
stage1 // serial
stage 2 // parallel_for
stage 3 // parallel_for
stage 4 // serial (was stage2)
stage 5 // parallel_for
stage 6 // serial (was stage3)
Jim Dempsey
Xingjing_Lu
Yes, I made some mistakes when calling parallel_for().
But I still have another problem:
Thanks!
Xingjing_Lu
jimdempseyatthecove wrote:
Quote:
Xingjing Lu wrote:
hi,
stage1 // serial
parallel_for
parallel_for
stage2 // serial
parallel_for
stage3 // serial
stage1 // serial
Jim Dempsey
Yes, What I want to do is  similar what you said above, but I cannot do this directly, because there are order constrains between different tokens.
RafSchietekat
Just to be sure, order constraints that are not addressed by serial_in_order?
(2014-08-09 Added after #7) Apparently I overlooked #4...
Alexey-Kukanov
