Hello everyone,
When I declare a concurrent_vector like :
concurrent_vector< data1D > myData1D ;
/*struct data1D
Color X , Y ; // struct of Red, Green and Blue
point2D imgPos ; // struct of int PositonX and PositionY
It works well.
When I want to use cache_aligned_allocator, if it's a simple data type
like "int", not problem, but if I use it for my data1D struct like :
concurrent_vector< cache_aligned_allocator > myData1D ;
And try to used the push_back() funtion,
I get the following error:
no matching function for call to
tbb::concurrent_vector<:CACHE_ALIGNED_ALLOCATOR><:DATA1D>,
tbb::cache_aligned_allocator<:CACHE_ALIGNED_ALLOCATOR><:DATA1D>
> >::push_back(myNameSpace::data1D&)
myNameSpace is a namespace where I declare the data1D struct
Thanks a lot for any help.
/*struct data1D
It works well.
Quoting - ahmedg
Quoting - Anton Pegushin (Intel)
Hi, it seems that you're declaring a vector of tbb::cache_aligned_allocators... First template parameter should be just myNameSpace::data1D.
Hello Anton,
Many thanks, that was the error.
Have a nice day :)
