I'm developing a multi-threaded application in C using pthreads on Linux but I need to avoid heap contention when allocating memory, hence I want to use the scalable memory allocation routines provided by TBB, namely malloc, realloc, calloc and free.
Before I switch however, I need to know will those routines work with pthreads and are the library functions memmove/memcopy compatible with these TBB routines too?
Can anyone help answer this?
Many thanks.
Yes, it should work.
