Just a quick question on something I can't pick up from the examples - recycle_as_continuation is supposed to prevent me from having to reallocate a task after every time it returns, correct? If so, where do I use it?
Example:
So I want this code to continually spawn, return, spawn, return. This is just a simplified version of my code which waits on many more tasks before the loop is started again. I want to be able to continue to spawn the tasks without having to reallocate every time.
I tried putting recycle_as_continuation in the execute() of myTask but my system freezes up.
Any help is appreciated
Example:
[cpp]while(isRunning) { MyTask& myTask = *new(task::allocate_child()) MyTask(); set_ref_count(2); spawn_and_wait_for_all(myTask); }[/cpp]
I would call that a bit oversimplified (no parallelism possible, just overhead), so I can't see what exactly you're trying to do, but perhaps it will work if you use recycle_as_child_of(*parent()) instead, because recycle_as_continuation() is about something else.
You could have a look at the TBB's tree_sum example (in the "examples/task/tree_sum" folder). TBB headers also use this method in a few places, but they are part of the code with quite non-trivial logic, and therefore are likely not a good examples.
In general you use recycle_as_continuation as an optimization in the following scenario. You have a task that creates a few child tasks and then needs to execute some code after these new tasks are completed. The most starightforward way is to use one of the wait_for_all() methods to wait for the child tasks completion, and then to execure post-processing code in the same task. But direct usage of wait_for_all() from inside other tasks is generally a bad practice because it may lead to excessive call stack consumption and incurs additional overhead.
Instead you:
::execute() method in tbb/parallel_for.h header.
Note also that N should be a small number, 2 or 3. If you need to allocate and spawn more children, do it in a biinary or ternary tree like manner instead (see tbb::parallel_invoke implementation for example), otherwise your application scalability will suffer.
Instead you:
- Recycle the current task as continuation
- Allocate N children
- Set the current task's refcount to N (not N+1)
- Spawn N-1 children
- Set a data member (e.g. boolean flag) that designates this task as a continuation (so that when it is invoked next time you could execute another branch of code)
- Return N-th child task to bypass its spawning (it's another recommended and widely used optimization).
How efficient is spawn_and_wait_for_all() compared to bypassing the scheduler in step 6 and using wait_for_all(): close to the latter, halfway, ...?
They both avoid the cost of spawn, but any wait_for_all() executes additional prologue/epilogue code that tends to grow with more and more functionality added to the scheduler.
But the main problem with wait_for_all() in its current incarnation is that it traps the current call stack, which is fraught with a number of potentially dire consequences:
1) call stack consumption well beyound that of a serial equivalent (because it opens up a way for recursion)
2) inability to redistribute workers between different masters
3) [rare in practice] deadlock if user application calls wait_for_all() under a locked mutex
Thanks for the replies. Being new to parallel design, I'll just explain my overall design and maybe there is a better way to do it than the way I am doing it where I can avoid the overhead.
I have 2 main task trees, and I need the second tree to run after the first tree (second tree relies on first tree's updated data). To do this I was going to run the first task tree and then when all its child tasks return, run the second task tree - but I also didn't want to have to keep reallocating tasks when they are basically just reused. Is there a better way to do this? Again this is generalized code but it mirrors my own code closer than my first example.
[bash]// main loop
while(true)
spawn_root_and_wait(taskTree1); spawn_root_and_wait(taskTree2); }
// Task tree 1 { MyTask& myTask = *new(task::allocate_child()) MyTask(); MyTask& myTask2 = *new(task::allocate_child()) MyTask(); MyTask& myTask3 = *new(task::allocate_child()) MyTask(); MyTask& myTask4 = *new(task::allocate_child()) MyTask(); set_ref_count(5); spawn(myTask); spawn(myTask2); spawn(myTask3); spawn_and_wait_for_all(myTask4); return NULL; } // Task tree 2 { MyTask2& myTask = *new(task::allocate_child()) MyTask2(); MyTask2& myTask2 = *new(task::allocate_child()) MyTask2(); MyTask2& myTask3 = *new(task::allocate_child()) MyTask2(); MyTask2& myTask4 = *new(task::allocate_child()) MyTask2(); set_ref_count(5); spawn(myTask); spawn(myTask2); spawn(myTask3); spawn_and_wait_for_all(myTask4); return NULL; } [/bash]
This does not exactly clear things up, but have you tried our advice above already? Anyway, don't get too focused on recycling tasks based on your experience with built-in memory allocation (TBB's scalable allocator is a lot more efficient): just get your program right, have the tasks do something non-trivial, and recycle opportunistically.
