replacement of STL::deque
softarts
on multithread environment, the STL consume too much resource to maintain its freelist (profile with vtune):
i.e.,every container use pthread_mutex_lock to guard the freelist:
can I use TBB to replace stl:deque,vector? and TBB will help to solve this problem?
stl_alloc.h:
template
class __default_alloc_template
static void*
allocate(size_t __n)
else
_Obj* volatile* __my_free_list = _S_free_list
+ _S_freelist_index(__n);
// Acquire the lock here with a constructor call. This
// ensures that it is released in exit or during stack
// unwinding.
_Lock __lock_instance;
_Obj* __restrict__ __result = *__my_free_list;
if (__builtin_expect(__result == 0, 0))
__ret = _S_refill(_S_round_up(__n));
else
*__my_free_list = __result -> _M_free_list_link;
__ret = __result;
if (__builtin_expect(__ret == 0, 0))
__throw_bad_alloc();
RafSchietekat
Black Belt
TBB's container objects are not drop-in replacements for the apparent equivalents in STL, and can't be because of different assumptions. You should study the specifications to see whether they suit your purpose.
If your STL objects are not used across threads, so their only problem is the performance of allocation, and the problem is not at the level of C++ new/delete (which can also be replaced), maybe you could specify your own allocator, and of course use scalable_{malloc,free} for its implementation? Just a thought, I have not looked at the details.
(Added 2010-03-09) That would of course be scalable_allocator, as Alexey writes below.
Alexey-Kukanov
TBB also provides scalable_allocator suitable to use with STL containers. See scalable_allocator.h. You will need to link with libtbbmalloc.so on Linux; on Windows, tbbmalloc.lib is linked automatically via #pragma comment(lib).
