simple fibonacci program segmentation fault
rockingsoul
I am just starting to learn TBB, and I tried to implement a simple Fibonacci number generator program mentioned in the Intel Technology Journal:
http://www.intel.com/technology/itj/2007/v11i4/5-foundations/4-tbb.htm
I just copied and paste the code from the journal page, and made my own MAIN. It compiles, but when I try to run it, it gives me a segmentation fault. The Serial portion of the code works fine. it seems that there is something wrong with the parameter passing, since the execution would not even jump into the execute() function (printf("checkpoint \n") wouldn't print anything in there) I would really, really appreciate if you could point me to the possible direction as what is wrong with the code below. Thanks a lot here first!
/***Fib***/
using namespace std;
using namespace tbb;
int CutOff = 20;
long SerialFib( long n )
if ( n<2 )
return n;
else
return SerialFib(n-1) + SerialFib(n-2);
///////////////////// Parallel methods ////////////////////////
class FibTask: public task
public:
const long n;
long* const sum;
FibTask( long n_, long* sum_ ) : n(n_), sum(sum_) {}
task* execute()
printf("checkpoint \n");
if( n {
*sum = SerialFib(n);
else
long x, y;
FibTask& a = *new( allocate_child() )
FibTask(n-1, &x);
FibTask& b = *new( allocate_child() )
FibTask(n-2, &y);
set_ref_count(3);
spawn( b );
spawn_and_wait_for_all( a );
*sum = x+y;
return NULL;
long ParallelFib ( long n )
long sum;
FibTask& a = *new(task::allocate_root())
FibTask(n, ∑);
task::spawn_root_and_wait(a);
return sum;
/////////////////////////// Main ////////////////////////////////////////////////////
//! program entry
int main(int argc, char* argv[])
long NumbersCount = argc>1 ? strtol(argv[1],0,0) : 500;
long sum;
printf( "Fib number %d \n", NumbersCount );
sum = ParallelFib ( NumbersCount );
//sum = SerialFib ( NumbersCount );
printf( "Result is %d \n", sum );
return 0;
RafSchietekat
Valued Contributor III
In main(), you'll need something like "tbb::task_scheduler_init anonymous;".
RafSchietekat
rockingsoul
Quoting - Raf Schietekat
Thank you Raf, that is it!
