task_scheduler_init creation and release
hedgehogest
Hi, guys,
The description of TBB task_scheduler_init is
Detailed Description
Class representing reference to tbb scheduler.
A thread must construct a task_scheduler_init, and keep it alive, during the time that it uses the services of class task.
I am not sure the meaning of the word A thread . Does this mean main thread or the the thread where new task is created.
Could I only create task_scheduler_init only once. Or every thread when new task is going to be created?
RafSchietekat
Valued Contributor III
"Using task_scheduler_init is optional [since] Intel TBB 2.2."
hedgehogest
Thanks. Since I am using 3.0, so there is no need to use task_scheduler_init when creating task ,and no performance impact, right?
RafSchietekat
Normally you needn't worry about it, and rarely will it be what you'll look at to improve performance.
