tbb concurrent_hash_map implementation
raman__rohit
I am trying to use tbb’s concurrent_hash_map to increase my application’s concurrent performance. Read up about it and implemented it
according to my application but I am seeing crashes..
So, my application is a multi threaded application where I am storing pairs, key is char* and the value is integer. Pseudo code looks like this:
    void  storeName(const char * name)   {
              int id=0;
              // This creates an pair object of name and index
              pair object(name);
              // concurrent_hash_table is an object of tbb::concurrent_hash_map and is declared in .h file
              // read_lock is a const accessor for reading. This find function searches for char* in the table
             // and if not found, create a write_lock.
              bool found = concurrent_hash_table.find(read_lock, name);
           if (found == FALSE) {
                        concurrent_hash_table.insert(write_lock, name);
// Get integer id somehow.
write_lock->second = id;
write_lock.release();
             } else {
// if the name is found in the table then get the value and release it later
id = read_lock->second;
read_lock.release();
As per my understanding, I am good with the implementation but as I said, there are multiple crashes coming when find returns me FALSE.
Crash have traces of mutexs as well.
Please suggest. Eagerly waiting.
