I am new in using tbb for parallel computing. I want to run the example in "\examples\GettingStarted\sub_string_finder". I did these in the following steps:
1. ran the \bin\tbbvars.bat by double clicks.
2. open the solution in \examples\GettingStarted\sub_string_finder\msvs\sub_string_finder.sln
3. the VS advices me to update some setting, I accept it.
4. build the project
Then I got the error MSB3073. It happend in the Microsoft.CppCommon.targets.
Error MSB3073 The command“call "D:\zw\CGAL\tbb2019_20190605oss\examples\GettingStarted\sub_string_finder\msvs\\..\..\..\common\copy_libraries.bat" intel64 debug "C:\Users\admin\AppData\Local\Temp\tbb_examples\x64\Debug\" :VCEnd” exited with code 1.
I check some webs and in the "https://developercommunity.visualstudio.com/content/problem/256692/intel-tbb-clone-and-build-error.html". It related: "Looks like the projects in the solution set up Output and/or Intermediate directory to be under %TEMP% dir, which can cause problems with incremental build. To fix the working you need to change project properties. For more support please contact Intel."
So I change the intermediate and Output directory of the project. The error was given as before.
"the command“call "D:\zw\CGAL\tbb2019_20190605oss\examples\GettingStarted\sub_string_finder\msvs\\..\..\..\common\copy_libraries.bat" intel64 debug "D:\zw\CGAL\tbb2019_20190605oss\examples\GettingStarted\sub_string_finder\msvs\x64\Debug\":VCEnd” exited with code 1.
Now I have no ideas how to fix the error. Do I have to revise the Makefile or the "copy_libraries.bat"?
Thank you for any suggestions.
Wei, Zhang
I found a solution to modify the "PostBuildEvent Path" to an absolute path or copy the dlls manually and close the PostBuildEvent.
