Hello !!
TBB gives this error while compiling the code. Any suggestions?
tbb_stddef.h:312:10: error: ‘void tbb::internal::no_assign::operator=(const tbb::internal::no_assign&)’ is private
void operator=( const no_assign& );
compilation terminated due to -Wfatal-errors.
on gcc version 4.9.2 (Debian 4.9.2-10)
thanks
no_assign is a special type that was created to mark types that should not be assigned. What is the code that leads to the error?
I used older version of tbb (v4.2) and it fixed my issue.
However, finding which part of my template-based code led to this error might take too much time. I will report it if i am able to reproduce it on smaller piece of code.
Could you share the compiler output log (not to waste time for a small reproducer)? Perhaps, it can give us some hint what can cause the issue. If the output is huge try to cut only the first error. If you are worried about confidential information, replace your type, class and function names, with something, e.g. "xxxxx".
I think I also have a similar error. I am trying to compile CGAL library with the latest intel tbb stable update and I get this compilation error:
In file included from /opt/intel/tbb/include/tbb/concurrent_hash_map.h:24:0, from /usr/include/CGAL/Profile_counter.h:72, from /usr/include/CGAL/Uncertain.h:26, from /usr/include/CGAL/assertions.h:344, from /usr/include/CGAL/basic.h:42, from /usr/include/CGAL/Cartesian/Cartesian_base.h:28, from /usr/include/CGAL/Simple_cartesian.h:28, from /usr/include/CGAL/Exact_predicates_inexact_constructions_kernel.h:28, from /home/satish/cgal/demo/Mesh_3/Polyhedron_type.h:6, from /home/satish/cgal/demo/Mesh_3/C3t3_type.h:4, from /home/satish/cgal/demo/Mesh_3/Scene_c3t3_item.h:5, from /home/satish/cgal/demo/Mesh_3/Scene_c3t3_item.cpp:3: /opt/intel/tbb/include/tbb/tbb_stddef.h: In instantiation of ‘typename __gnu_cxx::__enable_if<(! std::__is_scalar<_Tp>::__value), void>::__type std::__fill_a(_ForwardIterator, _ForwardIterator, const _Tp&) [with _ForwardIterator = tbb::recursive_mutex*; _Tp = tbb::recursive_mutex; typename __gnu_cxx::__enable_if<(! std::__is_scalar<_Tp>::__value), void>::__type = void]’: /usr/include/c++/4.9/bits/stl_algobase.h:740:14: required from ‘void std::fill(_ForwardIterator, _ForwardIterator, const _Tp&) [with _ForwardIterator = tbb::recursive_mutex*; _Tp = tbb::recursive_mutex]’ /usr/include/c++/4.9/bits/vector.tcc:470:16: required from ‘void std::vector<_Tp, _Alloc>::_M_fill_insert(std::vector<_Tp, _Alloc>::iterator, std::vector<_Tp, _Alloc>::size_type, const value_type&) [with _Tp = tbb::recursive_mutex; _Alloc = std::allocator<tbb::recursive_mutex>; std::vector<_Tp, _Alloc>::iterator = __gnu_cxx::__normal_iterator<tbb::recursive_mutex*, std::vector<tbb::recursive_mutex> >; typename std::_Vector_base<_Tp, _Alloc>::pointer = tbb::recursive_mutex*; std::vector<_Tp, _Alloc>::size_type = long unsigned int; std::vector<_Tp, _Alloc>::value_type = tbb::recursive_mutex]’ /usr/include/c++/4.9/bits/stl_vector.h:1073:44: required from ‘void std::vector<_Tp, _Alloc>::insert(std::vector<_Tp, _Alloc>::iterator, std::vector<_Tp, _Alloc>::size_type, const value_type&) [with _Tp = tbb::recursive_mutex; _Alloc = std::allocator<tbb::recursive_mutex>; std::vector<_Tp, _Alloc>::iterator = __gnu_cxx::__normal_iterator<tbb::recursive_mutex*, std::vector<tbb::recursive_mutex> >; typename std::_Vector_base<_Tp, _Alloc>::pointer = tbb::recursive_mutex*; std::vector<_Tp, _Alloc>::size_type = long unsigned int; std::vector<_Tp, _Alloc>::value_type = tbb::recursive_mutex]’ /usr/include/c++/4.9/bits/stl_vector.h:716:42: required from ‘void std::vector<_Tp, _Alloc>::resize(std::vector<_Tp, _Alloc>::size_type, std::vector<_Tp, _Alloc>::value_type) [with _Tp = tbb::recursive_mutex; _Alloc = std::allocator<tbb::recursive_mutex>; std::vector<_Tp, _Alloc>::size_type = long unsigned int; std::vector<_Tp, _Alloc>::value_type = tbb::recursive_mutex]’ /usr/include/CGAL/Spatial_lock_grid_3.h:629:28: required from here /opt/intel/tbb/include/tbb/tbb_stddef.h:318:10: error: ‘void tbb::internal::no_assign::operator=(const tbb::internal::no_assign&)’ is private void operator=( const no_assign& ); ^ /opt/intel/tbb/include/tbb/tbb_stddef.h:327:7: error: within this context class no_copy: no_assign { ^ /opt/intel/tbb/include/tbb/tbb_stddef.h:340:7: note: synthesized method ‘tbb::internal::no_copy& tbb::internal::no_copy::operator=(const tbb::internal::no_copy&)’ first required here class mutex_copy_deprecated_and_disabled : no_copy {}; ^ In file included from /opt/intel/tbb/include/tbb/tbb.h:72:0, from /usr/include/CGAL/Concurrent_compact_container.h:37, from /usr/include/CGAL/Triangulation_data_structure_3.h:44, from /usr/include/CGAL/Triangulation_3.h:43, from /usr/include/CGAL/Regular_triangulation_3.h:34, from /usr/include/CGAL/Mesh_triangulation_3.h:30, from /home/satish/cgal/demo/Mesh_3/C3t3_type.h:8, from /home/satish/cgal/demo/Mesh_3/Scene_c3t3_item.h:5, from /home/satish/cgal/demo/Mesh_3/Scene_c3t3_item.cpp:3: /opt/intel/tbb/include/tbb/recursive_mutex.h:39:7: note: synthesized method ‘tbb::internal::mutex_copy_deprecated_and_disabled& tbb::internal::mutex_copy_deprecated_and_disabled::operator=(const tbb::internal::mutex_copy_deprecated_and_disabled&)’ first required here class recursive_mutex : internal::mutex_copy_deprecated_and_disabled { ^ In file included from /usr/include/c++/4.9/algorithm:61:0, from /usr/include/CGAL/config.h:289, from /usr/include/CGAL/basic.h:29, from /usr/include/CGAL/Cartesian/Cartesian_base.h:28, from /usr/include/CGAL/Simple_cartesian.h:28, from /usr/include/CGAL/Exact_predicates_inexact_constructions_kernel.h:28, from /home/satish/cgal/demo/Mesh_3/Polyhedron_type.h:6, from /home/satish/cgal/demo/Mesh_3/C3t3_type.h:4, from /home/satish/cgal/demo/Mesh_3/Scene_c3t3_item.h:5, from /home/satish/cgal/demo/Mesh_3/Scene_c3t3_item.cpp:3: /usr/include/c++/4.9/bits/stl_algobase.h:693:11: note: synthesized method ‘tbb::recursive_mutex& tbb::recursive_mutex::operator=(const tbb::recursive_mutex&)’ first required here *__first = __value; ^
