Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
tbb_thread
sunnyboy_zj
Intel TBB 2.1 has a new class that is tbb_thread. What is it`s function? How to work? Is there somecode samples ?
Thanks in advance.
Bartlomiej
Just have a look at the Reference Manual: http://www.threadingbuildingblocks.org/uploads/81/91/Latest%20Open%20Source%20Documentation/Referenc... , Section 9.
Tbb_thread is simply a wrapper around the threads native to the platform and allows functionality similar to Boost threads, POSIX threads, etc.
It does not combine well with the task-driven model, but is sometimes convenient.
Bartlomiej
